I tried Peter Grainge's Show All/Hide All One-Button method, and it's great. But I want an updated look with a link and the +/- signs, just like the Help in Microsoft applications (example: MS Word 2007, Change or Set Page Margins topic). Don't have coding experience, and wonder how to implement that?
Hi, Carol,
A long time ago (pre-Office 2007), I extracted from a Microsoft Help file the JavaScript file that provides exactly this functionality, and used it in one of my own Help projects. The script is rather complex and runs to several hundreds of lines of code, but I can send it to you off-list if it's of any interest.
If you have the Microsoft Help 2.0 runtime components installed, you should be able to use a tool like FAR to look inside the Word 2007 Help file and retrieve the script file.
http://helpware.net/mshelp2/h20.htm
http://helpware.net/FAR/index.html
Pete
Hi there
In addition to what Pete said, you should also investigate Peter's site a bit further. He has a section where he describes adding a "twisty" to the link. The twisty may be any image you choose. So you could create the images you need quite easily and use them to accomplish your goal.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
Are 'twisties' built into RH8 now? I seem to remember reading it was, but haven't had time to look at it.
Hi there
Yep, Twisties are a feature of RoboHelp 8. You add them in the Style sheet.
Cheers... Rick
Rick,
Good point about Twisties. I did discover them and am using on my
project. Feel like that feature, along with Show/Hide All, really enables
a clear presentation of information with the drop down and expanding text.
A user can easily see the big picture, drill down to what they want, yet
not be overwhelmed with too much detail.
--Carol
Thanks for confirming the twisties functionality, Rick.
Pete,
Thank you for the response. Yes, I'd appreciate if you could share the
Javascript file with that functionality. Would you also be able to
describe what code I must add to the other RoboHelp files and were to put
the code or other files. For Peter Grainge's method, I added code to each
HTML page, two button graphics to the Image files and one to Baggage,
Thanks so much.
--Carol
cansorge@cgsinc.com
Pete Lees <forums@adobe.com>
To:
Carol Ansorge <cansorge@cgsinc.com>
Date:
09/26/2009 06:42 AM
Subject:
How do you create Show All/Hide All like in MS Help apps?
Hi, Carol,
Pete
Still looking for an answer: how to modify Grainge's One-Button method for the Show All/Hide All button so that it visually displays the +.gif with Show All link and - .gif with Hide All link, rather than the gray Show All and Hide All buttons in Grainge's solution.
--Carol
What Carol wants is a + button instead of a Show All button but then to have a link alongside that says Show All. That would require different scripting so I have suggested a graphic " + Show All "
