Hello everyone,
Within RoboHelp, I was able to write a JavaScript function for a link that asks our customer if a topic was helpful. The code basically populates the topic name in the subject line in the e-mail to prevent us from entering the topic name for each topic. Basic stuff. Anyway, if I put the code in the topic itself and call the function, it works beautifully. But if I reference an external file with the traditional reference tag, I have no luck and an "object not found" error message displays, which tells me that it cannot locate the .js file -- it is in my project folder. No dice.
Any thoughts on this? Has anyone experienced this before? I am using RoboHelp 7.
Is your script attached as a baggage file to your project? If not, the file won't make it to your output.
Greet,
Willam
Thanks for the quick response.
I have imported the file as a baggage file and referenced it in the footer of the topic. The error still displays.
Nothing I can tell you like this than you already know. Can you post your HTML file and .js (rename it to .txt!) file so I can have a look?
Greet,
Willam
In the top of your HTML file stands an empty function: <script language=JavaScript>breadcrumbs()</script>. This is causing the error in your CHM. Remove this, or create a valid function.
Your script works fine in both CHM and WebHelp, but only the CHM gives an error message because of the empty function.
Greet,
Willam
Well, that was leftover from when I deleted some content. My mistake.
I removed that and I am still receiving the same error message, however.
