3 Replies Latest reply: Sep 28, 2009 12:29 PM by jod-zeee RSS
    Adjustments are not being applied
    jod-zeee Community Member
      I'm trying to adjust the threshold on an image and it doesn't seem to be working.
      I opened a scanned PDF, converted it from Bitmap to Grayscale, and adjust the threshold.
      It gives me a preview of what I want, then I click OK, and the adjustment goes away. I tried a few other adjustments and the same thing happens. I tried using an adjustment layer and it shows the correct result, but if I try to merge or even save the file as a JPG, the adjustment goes away.
      Any ideas what's happening, what I'm doing wrong, what I'm missing?
      Jo
        • 1. Re: Adjustments are not being applied
          Gyno-jiz Community Member
          The bitmap image has only 100% white and 100% black pixels. Applying threshold to these pixels will have no effect (even if PS applies threshold to a sub sampled preview image which is confusing you).
          Converting it to grayscale doesn't initially affect the values of the bitmap pixels (100% white or 100% black), unless you enter a number larger than 1 in the size ratio dialogue when converting. So you can either make it grayscale by entering say 2 in the size ratio dialogue (which will halve your file resolution, or pixel dimensions), or you can apply a slight blur to the image before applying the threshold adjustment layer.
          If the image is lower in resolution (below 600 ppi), you might also be able to just up the resolution by a factor of two and let PS' bicubic smoother algorithm create the gray pixels needed to have threshold have any effect. It depends some on what you're trying to do with the image.
          Preview at 100% zoom while you work for a more accurate preview (instead of at 50 or 25% as you were doing in the first place).
          • 2. Re: Adjustments are not being applied
            Thank you that makes sense. I thought that might be the case, but as you pointed out, the preview confused me!
            I thought I had successfully applied threshold on a similar image only minutes before, but I must have done some interim step(s) to create gray pixels.
            Thanks again,
            Jo
            • 3. Re: Adjustments are not being applied
              It just occurred to me. I had rotated the first image a touch after converting it to grayscale. That would have created some gray pixels.
              It all makes sense now! Thanks again for your help. I love these forums!
              Jo
