1. Re: Receiving error when ampersands present
BKBK Sep 29, 2009 1:11 AM (in response to OgreOne)I am a confused. There are 4 possible things that could be going on here.
1) You say upload, but what you seem to be doing is using a form to submit a line of text.
2) Uploading is normally for a file, not for text. The form field one uses for uploading is of type file, not text.
3) An upload form requests the path to a file on the client, not a URL.
4) What error message do you get? Coldfusion or MySQL?
How can I pass the information form a text input field into MySQL
I used the following code to save the text http://127.0.0.1:8501/workspace/tests/page4763.cfm?a=1234&b=5678, without any problems.
<!--- test_tbl has a single column, myString[type varchar(200)]--->
<cfif isdefined("form.x")>
<cfquery name="q" datasource="myDSN">
insert into test_tbl(myString) values('#form.x#')
</cfquery>
</cfif><cfoutput><form action="#cgi.SCRIPT_NAME#" method="post"></cfoutput>
<input name="x" type="text">
<input name="s" type="submit" value="send">
</form> -
2. Re: Receiving error when ampersands present
OgreOne Sep 29, 2009 5:53 AM (in response to BKBK)Sorry for the confusuin. I meant submit, not upload. In a simple form, this is my line of code for the field:
<input type="text" name="url" value="" size="60" />
Upon submit, it would input the URL string into the URL field in the MySQL db. However, if the URL has an ampersand, for example (Fake URL for demonstration): http://forums.adobe.com/post!reply.jspa?message=2280267&2343, I wpould get the following CF error upon submition:
An error occured while Parsing an XML document.
The reference to entity "job" must end with the ';' delimiter. However, as long as I change all the & to & before submitting, all works fine. Then if I go and update it later, I the URL changes the & to & and I cannot submit the changes without changing the & back to &
Therefore, I figure there is an interpretation issue between MySQL and CF somewhere since it looks like MySQL recognizes & well enough to change it to & and spit it back out. MySQL field type is "text" and the collation is "latin1_swedish_ci"
3. Re: Receiving error when ampersands present
OgreOne Sep 29, 2009 7:01 AM (in response to OgreOne)I know I am an idiot... Forgot to mention that it must not be the CF/MySQL, BUT after I insert, I have it go to another cfm page to create an XML document, and so the parsing error must com from that.
Here's my Code to parse the XML document:
<cfquery name="GetNews" datasource="illegal">
SELECT *
FROM articles
ORDER BY art_timestamp DESC
</cfquery>
<cfoutput>
<cfxml variable="XMLDoc">
<?xml version="1.0" encoding="ISO-8859-1"?>
<rss xmlns:dc="http://purl.org/dc/elements/1.1" version="2.0">
<channel>
<title>News\</title>
<link>
http://www.mylink.com
</link>
<description>Get a daily News.</description>
<language>en-US</language>
<copyright>Copyright 2009, Office.</copyright>
<managingEditor />
<webMaster>Jojo@gmail.com</webMaster>
<pubDate>1 Aug 2009 0:00:00 GMT</pubDate>
<docs>http://blogs.law.harvard.edu/tech/rss</docs>
<ttl>240</ttl>
<cfloop query="GetNews">
<item>
<title>#GetNews.art_title#</title>
<link>
#GetNews.link_one#
</link>
<description>#GetNews.art_description#</description>
<date>#LSDateFormat(GetNews.art_timestamp,'MM/DD')#</date>
<pubDate>#LSDateFormat(GetNews.art_timestamp,'DDD, DD MMM, YYYY')#</pubDate>
</item>
</cfloop>
</channel>
</rss>
</cfxml>
</cfoutput>
<cfdump var="#XMLDoc#">
<cfset XMLText=ToString(XMLDoc)>
<cffile action="write" file="d:\home\sites\illegalimmigrationjournal.com\wwwroot\aznr\news\index.xml" output="#XMLText#">
<cflocation url="upload.cfm">So how, in my CF code do I make the XML parse the ampersand?
4. Re: Receiving error when ampersands present
BKBK Sep 29, 2009 9:27 AM (in response to OgreOne)The value encoding="ISO-8859-1" jumped out at me. What happens when you do the usual encoding="UTF-8"?
5. Re: Receiving error when ampersands present
OgreOne Sep 29, 2009 11:31 AM (in response to BKBK)I think it most likely has something to do with the encoding, but the other way around. I have another XML file on the same server that works correctly (created another using it's pattern) and it uses ISO-8859-1 and I do not have an error when inserting in the db and parsing the XML.
So paying attention to the encoding, When I parse the XML with the code above, and when the XML document is saved the parser actually writes UTF-8 instead of ISO-8859-1. I do not know how CF is defaulting to UTF-8 or why. What in my coding above tells it to, when clearly it says that it shoiuld print ISO-8859-1?
This has me baffled.Something is dynamically changing the way I save stuff. I am assuming CF since both XML pages reside on the same server and both are parsed.
6. Re: Receiving error when ampersands present
Joseph DeVore Sep 29, 2009 11:54 AM (in response to OgreOne)You need to escape any special XML characters < > ' " &. You can do this using the built in function XmlFormat() around your variables, or else wrap each value with <![CDATA[...]]>
<item>
<title>#XmlFormat(GetNews.art_title)#</title>
<link>#XmlFormat(GetNews.link_one)#</link>
<description>#XmlFormat(GetNews.art_description)#</description>
</item>
</cfloop>OR
<item>
<title><![CDATA[#GetNews.art_title#]]></title>
<link><![CDATA[#GetNews.link_one#]]></link>
<description><![CDATA[#GetNews.art_description#]]></description>
</item>
</cfloop>-JD
7. Re: Receiving error when ampersands present
BKBK Sep 29, 2009 1:26 PM (in response to OgreOne)So paying attention to the encoding, When I parse the XML with the code above, and when the XML document is saved the parser actually writes UTF-8 instead of ISO-8859-1. I do not know how CF is defaulting to UTF-8 or why. What in my coding above tells it to, when clearly it says that it shoiuld print ISO-8859-1?
You don't have to tell Coldfusion anything. As you should expect, Coldfusion defaults to its default encoding, which is UTF-8.
8. Re: Receiving error when ampersands present
OgreOne Sep 29, 2009 4:09 PM (in response to Joseph DeVore)You're AWESOME! I used the XmlFormat method. The other didn't seem to work, but problem solved!
Thanks to BKBK for helping as well!
