8 Replies Latest reply: Sep 29, 2009 4:09 PM by OgreOne RSS
    Receiving error when ampersands present
    OgreOne Community Member
      I am using CF and MySQL and have a simple form to upload.  The form requests an URL, however, if the URL contains and ampersand, I get an error.  How can I pass the information form a text input field into MySQL and have it parse the ampersand?
      Thanks in advance
        • 1. Re: Receiving error when ampersands present
          BKBK Community Member
          I am a confused. There are 4 possible things that could be going on here.
          1) You say upload, but what you seem to be doing is using a form to submit a line of text.
          2) Uploading is normally for a file, not for text. The form field one uses for uploading is of type file, not text.
          3) An upload form requests the path to a file on the client, not a URL.
          4) What error message do you get?  Coldfusion or MySQL?
          I used the following code to save the text http://127.0.0.1:8501/workspace/tests/page4763.cfm?a=1234&b=5678, without any problems.
          <!--- test_tbl has a single column, myString[type varchar(200)]--->
          <cfif isdefined("form.x")>
              <cfquery name="q" datasource="myDSN">
              insert into test_tbl(myString) values('#form.x#')
              </cfquery>
          </cfif>
          <cfoutput><form action="#cgi.SCRIPT_NAME#" method="post"></cfoutput>
          <input name="x" type="text">
          <input name="s" type="submit" value="send">
          </form>
          • 2. Re: Receiving error when ampersands present
            Sorry for the confusuin.  I meant submit, not upload.  In a simple form, this is my line of code for the field:
            <input type="text" name="url" value="" size="60" />
            Upon submit, it would input the URL string into the URL field in the MySQL db.  However, if the URL has an ampersand, for example (Fake URL for demonstration): http://forums.adobe.com/post!reply.jspa?message=2280267&2343, I wpould get the following CF error upon submition:
            An error occured while Parsing an XML document.
            The reference to entity "job" must end with the ';' delimiter.
            However, as long as I change all the & to &amp; before submitting, all works fine.  Then if I go and update it later, I the URL changes the &amp; to & and I cannot submit the changes without changing the & back to &amp;
            Therefore, I figure there is an interpretation issue between MySQL and CF somewhere since it looks like MySQL recognizes &amp; well enough to change it to & and spit it back out. MySQL field type is "text" and the collation is "latin1_swedish_ci"
            • 3. Re: Receiving error when ampersands present
              I know I am an idiot... Forgot to mention that it must not be the CF/MySQL, BUT after I insert, I have it go to another cfm page to create an XML document, and so the parsing error must com from that.
              Here's my Code to parse the XML document:
              <cfquery name="GetNews" datasource="illegal">
              SELECT *
              FROM articles
              ORDER BY art_timestamp DESC
              </cfquery>
              <cfoutput>
                <cfxml variable="XMLDoc">
                <?xml version="1.0" encoding="ISO-8859-1"?>
                <rss xmlns:dc="http://purl.org/dc/elements/1.1" version="2.0">
                  <channel>
                    <title>News\</title>
                    <link>
                    http://www.mylink.com
                    </link>
                    <description>Get a daily News.</description>
                    <language>en-US</language>
                    <copyright>Copyright 2009, Office.</copyright>
                    <managingEditor />
                    <webMaster>Jojo@gmail.com</webMaster>
                    <pubDate>1 Aug 2009 0:00:00 GMT</pubDate>
                    <docs>http://blogs.law.harvard.edu/tech/rss</docs>
                    <ttl>240</ttl>
                    <cfloop query="GetNews">
                      <item>
                      <title>#GetNews.art_title#</title>
                      <link>
                      #GetNews.link_one#
                      </link>
                      <description>#GetNews.art_description#</description>
                      <date>#LSDateFormat(GetNews.art_timestamp,'MM/DD')#</date>
                      <pubDate>#LSDateFormat(GetNews.art_timestamp,'DDD, DD MMM, YYYY')#</pubDate>
                      </item>
                    </cfloop>
                  </channel>
                </rss>
                </cfxml>
              </cfoutput>
              <cfdump var="#XMLDoc#">
              <cfset XMLText=ToString(XMLDoc)>
              <cffile action="write" file="d:\home\sites\illegalimmigrationjournal.com\wwwroot\aznr\news\index.xml" output="#XMLText#">
              <cflocation url="upload.cfm">
              So how, in my CF code do I make the XML parse the ampersand?
              • 4. Re: Receiving error when ampersands present
                The value encoding="ISO-8859-1" jumped out at me. What happens when you do the usual encoding="UTF-8"?
                • 5. Re: Receiving error when ampersands present
                  I think it most likely has something to do with the encoding, but the other way around.  I have another XML file on the same server that works correctly (created another using it's pattern) and it uses ISO-8859-1 and I do not have an error when inserting in the db and parsing the XML.
                  So paying attention to the encoding, When I parse the XML with the code above, and when the XML document is saved the parser actually writes UTF-8 instead of ISO-8859-1.  I do not know how CF is defaulting to UTF-8 or why.  What in my coding above tells it to, when clearly it says that it shoiuld print ISO-8859-1?
                  This has me baffled.Something is dynamically changing the way I save stuff.  I am assuming CF since both XML pages reside on the same server and both are parsed.
                  • 6. Re: Receiving error when ampersands present
                    Joseph DeVore Community Member
                    You need to escape any special XML characters < > ' " &. You can do this using the built in function XmlFormat() around your variables, or else wrap each value with <![CDATA[...]]>
                        <item>
                            <title>#XmlFormat(GetNews.art_title)#</title>
                            <link>#XmlFormat(GetNews.link_one)#</link>
                            <description>#XmlFormat(GetNews.art_description)#</description>
                        </item>
                    </cfloop>
                    OR
                        <item>
                            <title><![CDATA[#GetNews.art_title#]]></title>
                            <link><![CDATA[#GetNews.link_one#]]></link>
                            <description><![CDATA[#GetNews.art_description#]]></description>
                        </item>
                    </cfloop>
                    -JD
                    • 7. Re: Receiving error when ampersands present
                      You don't have to tell Coldfusion anything. As you should expect, Coldfusion defaults to its default encoding, which is UTF-8.
                      • 8. Re: Receiving error when ampersands present
                        You're AWESOME!  I used the XmlFormat method.  The other didn't seem to work, but problem solved!
                        Thanks to BKBK for helping as well!
