SOLVED
Question on Access Control
Avatar
Level 10
A very simple doubt,
I have created a process and a Task manager endpoint.
Now the process card appears for all users.
How to give access only to certain peoples to see and open the process cards??
Nith
1 Accepted Solution
Avatar
Correct answer by
Level 10
But do you mean the last Grid/Table of the Security Tab?
Yes
If so,
     1. the table is initially empty but still i'm able to see the card from workspace.
      Make sure your users are not part of the Administrator group. They should only have Workspace User role.
     2. Specify Run As is unchecked. Do i need to enable it?
     No.
     3. Also I tried to add an user name (not my name) but still i'm able to access the card
     Again check the roles of the user you're using.
Let me know,
Jasmin
Avatar
Level 10
In adminui, where you configured the endpoint, there is a security tab.
You can specify the users that have access to the card from there.
Jasmin
Avatar
Level 10
Thanks Jasmin.
If so,
Can you guide me what to do?
Nith
Avatar
Correct answer by
Level 10
Yes
If so,
     No.
Let me know,
Jasmin
Avatar
Level 10
You are correct,
All the developers are given Super Admin previlleges.
After updating the Role, it works properly.
Thanks Jasmin
Nith.
