i need another glossary vision content, actually, robohelp show my content in the same line, i want to show a custom content, something like a div, modal, a hint, etc...
Hi there
Using the RoboHelp built in Glossary function will not allow you to indent or categorize that way.
One possibility is to create a topic with the terms as you wish to see them. Then use that topic as your Glossary. You could link to it from the TOC or create a special Glossary button to open and present the topic.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
ok, tnks about the first category question, but we need to know something about de second question to... custom a view content from de glossary... inside the html text... we need a content in a popup, or a hint... we dont need a description after de word... like this print
Hi again
The Glossary in RoboHelp is quite literally WYSIWYG. There are no formatting options. To change the way it presents things would be to re-write some of RoboHelp and would likely be more painful than it is worth.
Your best bet in this situation is to go the "Topic Glossary" as I described and forego the RoboHelp Glossary functionality.
Cheers... Rick
Ok, thanks Rick
