1. Re: Auto-Save project files - CS4
Harm Millaard Oct 4, 2009 9:13 AM (in response to Jack Banatoni)Possibly the easiest way to use an autosave project is opening it and then use Save As..
2. Re: Auto-Save project files - CS4
Jack Banatoni Oct 4, 2009 9:24 AM (in response to Harm Millaard)That works, too. Thanks, Harm. Just wanted to be sure.
3. Re: Auto-Save project files - CS4
Harm Millaard Oct 4, 2009 9:37 AM (in response to Jack Banatoni)And it saves you the trouble of copying first, then renaming, then opening the renamed file and then using Save or Save As...
4. Re: Auto-Save project files - CS4
Bill Hunt Oct 4, 2009 10:41 AM (in response to Jack Banatoni)Jack,
One thing that I'd like to point out is that the incremented AutoSave files are not in sequence, relative to Time/Date. If one has the default of 5 AutoSaves, these will appear as [Project Name]_001 through _005. When looking in that folder, set the View to Details, and look closely at the Date/Time for each file. [Project Name]_003 might be newer, than _005. Each AutoSave file is overwritten, and AutoSave will cycle through the numbers set. It's a FIFO situation and has tripped up many. Check that Date/Time carefully.
Good luck,
Hunt
