1. Re: Previewing via DVI Monitor... possible?
Bill Gehrke Oct 2, 2009 4:27 PM (in response to sync2rhythm)Just use any old second (not in SLI or Crossfire mode) PCIe graphics card and monitor that can do 1920 x1200 for a third HD preview monitor.
2. Re: Previewing via DVI Monitor... possible?
sync2rhythm Oct 2, 2009 5:26 PM (in response to Bill Gehrke)Just use any old second (not in SLI or Crossfire mode) PCIe graphics card and monitor that can do 1920 x1200 for a third HD preview monitor.
Really?
So, will this:
#1 - Give me the option of setting it up exactly how they show it in the screengrab w/ 3 screens... whereas, I can have Premiere spread across 2 and a Full HD Program/Monitor (same as if I had an NTSC HD monitor) alongside my normal editing interface on the 3rd?
-or-
#2 - Will this just give me an extra monitor whereas I'll have to drag my Program/Preview window and expand it to full screen?
-- I would prefer a method that would give me option #1 so I can continue my edit while allowing someone sitting close by to see the FullScreen HD Program playing on the 3rd monitor.
______________________________
Although I am yet to hook it up, (stilll waiting on the WorkStation/NLE to arrive) Thank You Bill Gehrke for pointing me in the right direction.
http://forums.adobe.com/message/1980053#1980053 <--- CS4 HD Monitoring
"Since you are already running dual monitors you might just try installing a second graphics card and try to see if you can enable the "Playback Settings" to have your playback on a third screen."
RT_X2 Display.jpg 63.1 K
3. Re: Previewing via DVI Monitor... possible?
Bill Gehrke Oct 2, 2009 6:08 PM (in response to sync2rhythm) -
4. Re: Previewing via DVI Monitor... possible?
sync2rhythm Oct 3, 2009 3:02 PM (in response to Bill Gehrke)Bill Gehrke wrote:
Here is my two monitor setup:
Very cool! This IS the exact setup I'm hoping for with this new workstation... plus a Third monitor. (2 on bottom - 1 on top)
--- When using a Computer Monitor as your Full Screen Program monitor, is there a special way or tool you use to adjust its Color, Contrast, etc so you can trust it same as you would a calibrated NTSC Monitor?
5. Re: Previewing via DVI Monitor... possible?
JSS1138 Oct 4, 2009 3:43 PM (in response to sync2rhythm)so you can trust it same as you would a calibrated NTSC Monitor?
I wouldn't. Get a real HDTV for the task, and properly calibrate it.
