RH8 HTML.
I'm trying to publish a version of our help file to pdf, there are several topics that have swf files in the topics, but everytime I publish there is an error and no PDF output comes the only error I get is
Internal error encountered, Failed to generate Printed Documentation.
Am I missing something.....
I've tried this in blank new projects with a single topic and various swf files and the same error occurs everytime.
Thanks.
First try generating to Word instead of PDF.
Look in the Output pod for any messages.
Word publishes fine, with and without the swf file, of course the file doesnt show but I do get output.
however, PDF does not generate, with or without the swf file. I can't get pdf generated output at all, same error as before. But not a very specific error. this may be annoying to solve. 😕
To be quite sure, are you deselecting PDF, creating a Word document and then in Word going to File > Print and selecting the PDF printer?
No, when I'm trying to publish directly to PDF from RH I select pdf, and de-select Word. The reason for this is the embedded swf files that I have, I can manually embed them in PDFs that I create from Word. But that is a teadous process, and RH has pdf as an output option so I'm hopig to automate the whole thing.......why is there an issue with creating pdfs straight out of RH?
when I generate to word however, I do de-select pdf.
I'm trying to establish whether you have a general problem with creating PDFs from RH or if it is just this layout.
Yeah so am I, from what I can tell its all over RH.
I opened some of the sample projects that are provided, and I couldn't create PDFs from this either. I played around with the pdf settings, making them compatiable with various versions, and still nothing, that have completely different styles, CSS, layouts etc. It fails all over the place, perhaps its an error with Acrobat or something, rather than RH.
So I dont think its related to this particular project.
So with one of the samples if you turn off PDF, generate to Word and then create the PDF from Word, does it work?
So we have established that the problem is only if you try to create the PDF direct from RH. If you go via Word it is OK, albeit you don't get the SWF embedded.
See Item 33 in http://www.grainge.org/pages/authoring/rh7/using_rh7.htm on my site as that sounds like the problem. I know you are using RH8 but the fix is reregistration of an Acrobat file so it should work there too.
It didn't work. The dll re-registered successfully, but it didn't solve the issue in RH.
It still fails at the same time.
I made sure not to load anything when I rebooted, and ran the command. but still it crashes.
im going to get a new version of acrobat today (pro 9 extended)....perhaps this will solve the issue.
I havn't been able to find anyone with a similar issue online......
Look at the price of upgrading to TCS2 rather than just buying Acrobat 9. In some cases it is a better deal.
You might want to try the trial version first to make sure it works.
I installed the trial of Acrobat 9 and this solved the publishing to pdf problem.
Though, now that I can publish to pdf, it doesnt display my swf files in the pdf doc.
In a webhelp output, the swf file is there.
But in pdf it is not.
I've tried setting the changing the PDF compability settings etc in the PDF Settings area, but nothing has worked.....
Is it even possible to have swf files in a pdf produced from RH?
I can do it manually, but thats just a lot more work.
Thanks.
Does RoboHelp (in RH8) still create a word document before creating a PDF-document? It does in Robo7, even if you uncheck the box Generate Word DOC. It basically, Robo7 creates a Word document and then creates a PDF from the Word document.
I don't know of a way to add a SWF into word, perhaps adding an object. But Robo doesn't support this as far as I know.
Greet,
Willam
From looking at the output process, it looks like a doc file is created, then it generates a pdf from this.
I thought perhaps they would have some after publishing thing going on where they would embed the swf in the pdf.
But alas,RH doesnt seem to support a .swf file in a pdf. Very big shame that, considering how often I see, and use, animations and video files in PDFs.
suppose it will have to be a manual thing then.
one for the adobe request form.....
RH has to create a Word document as what else would it send to the PDF printer?
