3 Replies Latest reply: Oct 5, 2009 7:09 PM by SD_DEI_AH RSS
    CS4 Design Premium XP SP3 won't install Acrobat 9 stuck on "Preparing to install"
    SD_DEI_AH Community Member
      I've read through many posts on this subject but not sure I saw a resolution.  I am running XP SP3.
      I have installed all of the CS4 Desgin Premium except for Acrobat 9.
      To install the rest of CS4, required the Windows clean-up script and the CS4 Cleanup to remove trial versions of CS4.
      I thought all was well until I tried to run Acrobot 9 only discover it was not installed.
      I put the CD in and it listed as Acrobat 9 as the only appliaction available for install.  I clicked it and waited, for a long time,
      watching the "Preparing to Install".  Long time as in more than 20 minutes until I noticed that nothing was going on, the
      disk was not spinning, cpu usages was nearly nil.  I check that it is not the disk drive, I checked that antivirus was disable.
      I uninstalled Acrobat 8 and rebooted.  I ran the Adobe support advisor only for it to tell me there was no resolution.
      The module found no solutions to report for the selected log file.
      If you continue to have difficulties with the application,
      please contact Adobe Support: http://www.adobe.com/support
      System Information :
      Operating System = Windows XP Home Edition Service Pack 3
      Locale = en
      Clicked the "Package for Support" to send to Adobe and received " The storage server is unavailable ! Please try again later"
      I looked through the log file in the common files/adobe/installers folder and no "Return 3" like a previous tech note/post suggested.
      I browsed the CD and noticed that there did not seem to be "en_US" nor "_mul" for Acrobat like there is for the other programs in
      the payloads directory, I don't know if that means anything, just something I noticed. I attached a screenshot of disk 1 (used
      snagit to create since Acrobat is not currently installed)
      Like someone else in the forum, uninstalling would result in a great hardship given that I have painstainkenly converted several InDesign
      docs and setup more than a handful of client websites using Dreamweaver CS4.
      At this point, I've spent several days trying to figure it out and I am looking for alternatives to acrobat, having exhausted all ideas
      on how to resolve this.
      Please advise.
