SOLVED
Retrieve attributes from a signature?
Avatar
Level 2
I would like to get the end-user's name out of a digital signature (i.e., subject's name on the signature) while executing the postSign script, so that I can transcribe into a text field elsewhere in the document. I've spent hours surfing to find a solution for this. Is there a way to do it? Thanks for reading.
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
Look in the Acrobat scripting reference at the signature objct. I am quite certain that it is exposed through that object.
Paul
Avatar
Correct answer by
Paul
Avatar
Level 2
Thanks, that source of information worked out for me. For the benefit of others, here is the Adobe Javascript Scripting Reference document he identifed:
http://partners.adobe.com/public/developer/en/acrobat/sdk/AcroJS.pdf
... and then the help I was looking for is the desciption of SignatureInfo object. In the Livecycle javascript in my form, I can now go to the desired username attribute as follows
var digSig = event.target.getField ("MyForm[0]...MyPathstuff [0]...Signature [0]");
digSig.signatureValidate ();
If successful...
var sigInfo= digSig.signatureInfo (); // Gets SignatureInfo object
var sSigner = sigInfo.name;
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
