Please see the comments and questions embedded in this code snippet:
protected function btnGo_clickHandler(event:MouseEvent):void
// I fetch a bunch of photo subject records ("items"?) from a back end DB
getSBJsResult.token = baa_data_svc.getSBJs(edtSrch.text);
// How do I get the record count (item count) from the object returned above
// so that I can display it in the tab label in the next line --->
// Also, Is "+" the correct symbol for contatenation?
tabSBJs.label = 'Subjects: ' + Whu?
// Now I grab some photo session records, but I must feed it the unique ID from the FIRST
// record (item) in the result set retrieved above, how do I get that value (it's a string (GUID))
getSESsResult.token = baa_data_svc.getSESs( what goes here? );
// What every you show me above, I'll use on the line below. It still
// contains the dummy param value
getIMGsResult.token = baa_data_svc.getIMGs('BF3B9F5AC1C7422C8B79C66369EFDFE9');
Thanks in advance for any help.
Total Likes
