Cannot display pdf form with Adobe Reader 9.1.3
Avatar
Level 2
Since the last update of my Reader (last version is 9.1.3), I can't display pdf form in the workspace. I got a blank page.
Is anybody have the same problem?
Avatar
Former Community Member
I have the same problem too, I reported to the Help Desk and they said that common problem for version 9.1.3. While waiting to get it fixed, I have asked them to roll back to earlier version 9.1.2 and it works fine. If you got it fixed, please post here to share your tip. Thanks. Han
Avatar
Level 2
open your acrobat or any pdf file on hard drive
go to edit->preferences
in the side bar click internet and make sure  all the check boxes ( display pdf in browser is enabled) are checked.
try if it works
Avatar
Level 2
I checked and all checkboxes are checked.
We tried to update the reader to 9.2 version and the problem is still here.
Avatar
Have you found a solution to this yet?  I am seeing it with version 9.3.
John
Avatar
-  Go to the registry HKEY_CLASSES_ROOT > Software > Adobe >Acrobat> delete any older version that is older than the one you just updated to make sure it contains only the current one you have for both Acrobat Reader and/or Pro version since it did not removed when you uninstall or update.
- Also go the installed directory where you installed the Acrobat and delete any folder that contains older version, same here with the registry, it did not remove when you uninstall/update acrobat reader or pro.
The above steps also solve the problem of can not open pdf file within Internet Explorer or browser as well.
Han
Avatar
Level 3
I found two hit/miss workaround solutions.
#1:  When you get the blank white screen, simply hit the 'ALT' key.  Most of the time that seems to force the pdf to render to the screen.
#2:  Change the Internet Options to DESELECT 'Allow fast web view' and 'Allow speculate download..."  That worked on a couple of my machines.
But I still have not found a silver bullet answer.
