problem with barcode field alignment
Avatar
Level 1
hi
Im trying to add barcode field to my form. In the designer environment all seems ok but when previewing PDF the number below the barcode is cut.
Ive set field margins but it seems to make things worse.
Please see here screen shots that explain it visually.
Any help is appreciated.
Avatar
Former Community Member
I am assuming this is an EAN8 barcode.  What are the page and barcode dimensions?
Avatar
Level 1
Hi
Thanks for your comment.
This is EAN-13 code but the same occurs with any type of bar code I use.
page dimensions: A4
field dimensions: any.
one more thing: It seems that the margins works other way around. the more margin I put at the bottom of the field, the more cutting occurs on the number untill with margin of around 3 mm (depending on the field size) the barcode number at bottom completely disappears.
Please see here new photos:
thanks
