Has anyone built the forms and code for this API in CF? I don't have a specific problem - I'm just looking for some shared code so that I can perhaps save some coding time.
Shane
You might check for an Authorize.net project at RIA Forge.
http://www.riaforge.org
Shane,
It's pretty basic (from a 2007 site!) but here's an old Authorize.net payment script I had. Any form will do and, based on the CFHTTP I have below, you just replace your form field variables where I have session.cart.get____(). I included the snippet of code that pulled out the response from the Authorize.net returned data. Like I said, it's pretty basic but I hope it gets you started in terms of submitting payments to Authorize.net.
<!--- 4111-1111-1111-1111 (fake visa number) ---> <!--- https://secure.authorize.net/gateway/transact.dll ---> <!--- https://test.authorize.net/gateway/transact.dll --->
<cfhttp method="post" url="https://secure.authorize.net/gateway/transact.dll"> <cfhttpparam name="x_login" type="formfield" value="YOUR LOGON"> <cfhttpparam name="x_tran_key" type="formfield" value="YOUR TRANSACTION KEY"> <cfhttpparam name="x_method" type="formfield" value="CC"> <cfhttpparam name="x_type" type="formfield" value="AUTH_CAPTURE"> <cfhttpparam name="x_amount" type="formfield" value="#Trim(session.cart.getPayment().getTotal())#"> <cfhttpparam name="x_delim_data" type="formfield" value="TRUE"> <cfhttpparam name="x_delim_char" type="formfield" value="|"> <cfhttpparam name="x_relay_response" type="formfield" value="FALSE"> <cfhttpparam name="x_card_num" type="formfield" value="#Trim(session.cart.getPayment().getCardNumber())#"> <cfhttpparam name="x_exp_date" type="formfield" value="#session.cart.getPayment().getCardExpiration()#"> <cfhttpparam name="x_version" type="formfield" value="3.1"> <cfhttpparam name="x_invoice_num" type="formfield" value="#session.orderNumber#"> <cfhttpparam name="x_description" type="formfield" value="Order #DateFormat(Now(),'mm-dd-yyyy hh:mm')#"> <cfhttpparam name="x_first_name" type="formfield" value="#Trim(session.cart.getCustomer().getFirstName())#"> <cfhttpparam name="x_last_name" type="formfield" value="#Trim(session.cart.getCustomer().getLastname())#"> <cfhttpparam name="x_email" type="formfield" value="#Trim(session.cart.getCustomer().getEmail())#"> <cfhttpparam name="x_address" type="formfield" value="#Trim(session.cart.getCustomer().getAddress())#"> <cfhttpparam name="x_city" type="formfield" value="#Trim(session.cart.getCustomer().getCity())#"> <cfhttpparam name="x_state" type="formfield" value="#Trim(session.cart.getCustomer().getState())#"> <cfhttpparam name="x_zip" type="formfield" value="#Trim(session.cart.getCustomer().getZipCode())#"> <cfhttpparam name="x_email_customer" type="formfield" value="true"> <cfhttpparam name="x_merchant_email" type="formfield" value="EMAIL"> </cfhttp> <cfset api_response=cfhttp.fileContent />
<!--- check the response headers to ensure that payment was good ---> <cfscript> aryApiResponse = ListToArray(api_response, "|"); </cfscript> <cfif IsDefined("aryApiResponse") and ArrayLen(aryApiResponse) and Trim(aryApiResponse[1]) is not 1> <cfset paymentReceived = false /> <cfif ArrayLen(aryApiResponse) gte 4> <cfloop from="1" to="4" index="j"> <cfscript>
tmpError = "<em>Payment Error</em> " & aryApiResponse
& "."; ArrayAppend(session.aryCartErrors,tmpError); </cfscript> </cfloop> </cfif>
<cfelse>
<!--- we're good --->
</cfif>
