16 Replies Latest reply on Apr 18, 2011 8:07 PM by breteny
    Image Size Change
    visunique
      I need to know why when I open a raw downloaded jpg image (directly from my camera... I have done absolutely nothing with it) the image size in photoshop reads:
      Pixel Dimensions 7.97 M
      width 2048 pixels
      height 1360 pixels
      Document size
      Width 28.444 inches
      Height 18.889 inches
      Resolution 73 pixels/inch
      BUT
      When I open it again in Camera Raw and then click open image (in Photoshop) then save it as a psd it changes (without me changing it) to
      Document size
      Width 8.53 inches
      Height 5.667 inches
      Resolution 240 pixels/inch
      And... is this going to matter when I want to enlarge the photo for printing??? Because, I know, logically, going from a larger size to a smaller size will not destroy the quality of a photo but going from a smaller (in this case 8.53 x 5.667 to say 18 x 24) I am afraid will change the image quality tremendously.
        • 1. Re: Image Size Change
          Silkrooster Adobe Community Professional & MVP
          You have nothing to worry about. Camera Raw does not change the pixels in an image. It is a non destructive editor. When you have camera raw open look at the bottom center of the window for what looks like a URL link. Click on that and the properties will open. From here you can specify what ppi to use when it send the file to photoshop. As you will see for the size it will show only one size. For a raw or dng file the size can display muliple sizes but it does not save over top of a raw or dng file.
          For a jpg file, camera raw will save over the jpg file, but all changes are meta data. Therefore any program that does not recognize the meta data will not see the changes.
          Now for your concern and about damaging the file - The ppi is a multiplier for determining the final size of the print when you send it to the printer. It does not effect the pixels of the image it self because camera raw won't allow it.
          Lets say you wanted to print an image at 300 ppi, and the resolution of your image is 1600x1200. Take the 1600 and divide it by 300 then take the 1200 and divide that by 300 and that will tell you that it will print at 6" x 4". In this instance sense camera raw will not change the amount of pixels then that means when you change the ppi the physical size in inches will change or if you change the size then the ppi will change to accomodate the pixels of that image.
          I hope the above makes sense...
          • 2. Re: Image Size Change
            visunique Level 1
            I am not sure I am "getting it" as it sounds like tbe greater the resolution the smaller the print size and if that is so then logic tells me that if I wanted to enlarge the image (when it seems to turn my larger image automatically to say 4x6 300 DPI) it would come out pixelated. But if you say it is being preserved safely for quality enlargements I believe you.
            So, I clicked on that thing you told me to click on for camera raw and I want to know if there is a best setting for enlargements in those options and what res I should have it on if I want to keep the pic quality for enlargements.
            Options:
            8bits/channel (default)
            16bits/channel
            (it is automatically on 8bits/channel now by default)
            1542x1024 1.6MP
            2048x1360  2.8MP (default)
            3072x2040 6.3MP
            4096x2720 11.1MP
            (I shot it with a 6MP camera)
            I have been told that it needs to be a resolution of 350 to be a printable image so I changed the dpi setting to 350 which now gives me an image size of
            5.851x3.886 inches which seems terribly small to save for enlargement later. Maybe, again, I am still missing something.
            • 3. Re: Image Size Change
              Its best to leave the settings at their defaults.  If you were to select any of the sizes above default it would generate a pixelated image, but the original image is untouched.
              At 2048 x 1360 it will create a 6.82" x 4.52" image printed at 300ppi. This is the only time when camera will change the pixels when you specify a pixel value from that list. But that is for a new image only and does not effect the raw image.
              Looks like I was wrong about pixel size in the previous post. Apparently I check a jpg that was not from a camera. I assumed all jpg displayed only one size . But I check one from a camera and it does show a list. But that list is for exporting to photoshop so a new file is generate at that size, leaving the original jpg untouched. I appologize for that I should have double checked.
              • 4. Re: Image Size Change
                I didn't see the last part of your post. 300ppi should more than suffice for any print that is held at a comfortable arms length (about as far away as you normally look at a photo) The further away the photo will be the lower the ppi can be as the eye can not see the pixels as easy. You can get away with a lower ppi at arms length but it will be more noticable and will look pixelated.
                If you find the quality is still no there especially if you plan on printing at larger sizes, you may want to think about a higher MP camera.
                • 5. Re: Image Size Change
                  john cornicello (retired) Level 4
                  You are mixing apples and oranges here. At first you talk about pixel count for the JPG, but then you leave that off for the raw file.
                  2048x1360 pixels at 72 ppi and 8.53 x 5.667 inches at 240 ppi are the same thing.
                  Only the pixel dimentions matter. At 72 ppi that equals 28.444x18.889 inches. If you change the dpi to 240 the print size changes to 8.53x5.667. But the image is the same (no pixels are changed). If you change the ppi to 300 (without resampling the image) your print size will change to 6.827x4.533 inches.
                  By changing the PPI setting you are telling your printing software to place the pixels further apart or closer together. This won't matter while you are in Photoshop, but will matter if you place your file into a page layout program like InDesign.
                  John
                  • 6. Re: Image Size Change
                    Which particular 6mp camera are you using?
                    Are you working with raw files? Or are you opening a JPG in Camera Raw?
                    If raw, the 6mp camera should default to around 3072x2040 pixels, not 2048x1360 (which is only around 3 megapixels). If you are working in JPG, make sure the camera is set to its maximum file size and quality. From what you are saying, it sounds like the camera is set to only record at 3mp instead of 6 when working in JPG mode.
                    John
                    • 7. Re: Image Size Change
                      A 6mp image at 300 dpi should be 3072x2048 pixels, and will give a print at 10.24x6.827 inches. The numbers in your post (2048x1360) would indicate a 3mp image.
                      John
                      • 8. Re: Image Size Change
                        adobe2418
                        Good explanation.
                        What I think is most confusing to many people is that what you say seems
                        counterintuitive.
                        One would expect more ppi for a 28.444x18.889 inch image than for one that
                        is 8.53x5.667 inches.
                        CC
                        • 9. Re: Image Size Change
                          Its actually the opposite. PPI stands for pixels per inch. Since the pixels of the image is fixed the number of pixels within one inch must decrease in order for the physical size of the print to increase.
                          • 10. Re: Image Size Change
                            Try thinking about the image as if it was a balloon with dots on it. If you blow it up a little bit the dots are all close together and may form an image. As you blow it up more you still have the same number of dots on the balloon, but as it expands they move further apart and become less recognizable.
                            In the case of the print, you have the same number of pixels in both prints, but in the larger one they are expanded and lose quality.
                            So, yes, one would expect there to be more pixels per inch in a larger image IF both images had the same quality. But the larger one is going to be of lesser quality because the number of pixels available is a fixed quantity.
                            John
                            • 11. Re: Image Size Change
                              the_wine_snob Level 9
                              If you opened either image in PS, and chose Image>Image Size, making sure that Resample Image was unchecked, you'd see the Resolution go up, as you drop those large dimensions (in inches) down. Try it, and observe. Just open both, and change either the dimension, or the Resolution.
                              Good luck,
                              Hunt
                              • 12. Re: Image Size Change
                                Here's an example: I scan my 4 x 5 transparencies at 1000 ppi. If I open the resulting files in Photoshop, I see 4" x 5" x 1000 ppi (Resolution). If I uncheck Resample Image and choose 72 ppi, I get an image that is 69.444" x 55.556".
                                Some programs make the assumption that the user will want to view the resultant image on a computer monitor, hence the default 72 ppi. Other programs assume that the user will likely want to go to print, where the Resolution will really matter, and might default to, say 300 ppi. With that, I'd get 16.667" x 13.333" x 300 ppi. Does that make sense?
                                Good luck,
                                Hunt
                                PS - now stick that image into Video, where ppi/dpi do not matter, and you will only want to consider the pixel x pixel dimension.
                                • 13. Re: Image Size Change
                                  Saqibze
                                  Hi John,
                                  I need to know that, why camera raw dose change the image sizes? I don't want to change the image size, I want only the colour correction with camera raw.
                                  Saqib
                                  • 14. Re: Image Size Change
                                    John_Cornicello_Photo Level 2
                                    Camera raw doesn't change the size of the file unless you tell it to via the workflow options under the preview (it looks like a hyperlink listing the color space, bit depth, and size). And even then, it only changes the size of the file that opens into Photoshop. The original raw file is not changed at all.
                                    • 15. Re: Image Size Change
                                      yunie_ Level 1
                                      wow. thanks I have similar problem and this thread answered it perfectly.
                                      • 16. Re: Image Size Change
                                        breteny
                                        Hi friends
                                        We know that your problem is very short cut solve them.so your camera raw dose change the image sizes? I don't want to change the image size, so I want only the colour correction with camera raw.so image size change it.
