SOLVED
Change button color on click
Avatar
Level 2
Is there a way I can change a button color when the user clicks it? I want the button to start white then change to red when the user clicks it.
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
Add this code to the click event:
this.border.fill.color.value
= "255,0,0"
Paul
Avatar
Correct answer by
= "255,0,0"
Paul
Avatar
Level 2
Hi Paul,
Thank you for this information. It works great! Is there any way that I can set it to toggle on and off? So it can go red, then neutral, then red... or even better, is there a way to make it toggle between several colors (example: neutral, red, green, yellow)?
Thanks a bunch!
Avatar
Try this:
if
(this.border.fill.color.value == "255,0,0"){
= "255,255,255"
else {
= "255,0,0"
Paul
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
