I run Coldfusion 9 Beta, Coldfusion Builder Beta under Windows7. Also installed Subversion/tortoise.
How can I use Subversion within CF Builder? If I right click a projects and choose Team->Share project,I get a window prompting me to select a repository type. Nothing is listed in the white space below and I cannot add any repository types. Under Preferences->Team I have options "File Content", "Ignored Resources" and "Models". Cannot choose here for a version system (CVS/Subversion) as in Eclipse with Subclipse installed. Do I have to download Subclipse and add it to CFBuilder manually?
Thanks for any tips,
Marc
All Views of subversion are under subversion perspective. Go to Window->Open Perspective->Other and then choose 'SVN Repository Exploring' from the lsit.It will open up all the required views.
Evelin Varghese
By default subclipse is not packaged with cfbuilder.
So you will have to install subclipse as a plugin to cfbuilder and then use theSVN perspective.
Evelin Varghese
when I install subclipse I still don't see the svn perspective. the files all appear to be there in my eclipse folder and eclipse seems to think it's there but it doesn't show up. I went back to my old eclipse 3.32 and installed subversion 1.6x the same way and it works fine. This is a standalone version of cf builder with eclipse 3.42.
What is very strange is that I have been using the CF Builder Beta for awhile now and it has always had repository types listed. I have been working with VSS for my repository. However I am having the same issue since I installed CF Builder Beta 2. I have no options for repository type. Any ideas what happened to this feature?
Sincerely,
Braden
