31 Replies Latest reply on Sep 21, 2012 3:25 PM by Dakuwan
    Cybersource error on Coldfusion 9
    EstebanD
      We are trying to upgrade to Coldfusion 9 but we can't upgrade our cybersource implementation. We keep getting an error related to RSA libraries. I wonder if CF 9 includes some new libraries that have a conflict with Cybersource. Any ideas?
      Error StackTrace:
      java.lang.NoSuchMethodError: com.rsa.jsafe.CryptoJ.isFIPS140Compliant()Z
      at com.rsa.certj.CertJ.isFIPS140Compliant(Unknown Source)
      at com.rsa.certj.CertJ.(Unknown Source)
      at com.cybersource.security.SecurityContextJava.(SecurityContextJava.java:155)
      at com.cybersource.security.SecurityContext.getInstance(SecurityContext.java:31)
      at com.cybersource.ws.client.Signature.internalInitializeContext(Signature.java:104)
      at com.cybersource.ws.client.Signature.(Signature.java:39)
      at com.cybersource.ws.client.Client.soapWrapAndSign(Client.java:200)
      at com.cybersource.ws.client.Client.runTransaction(Client.java:103)
      at com.cybersource.ws.client.Client.runTransaction(Client.java:53)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:597)
      at coldfusion.runtime.java.JavaProxy.invoke(JavaProxy.java:97)
      at coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:2360)
        • 1. Re: Cybersource error on Coldfusion 9
          atspear
          Did you ever make any progress on this.  I'm running up against the same error, but I'm seeing it on CF 8 and 9.  What version are you using?
          • 2. Re: Cybersource error on Coldfusion 9
            EstebanD Level 1
            We haven't had any progress.
            We contacted Adobe but they declined to provide any tech support unless I pay for it, and my initial impression was that they will refer to Cybersource in a infinite loop :-)
            Cybersoure hasn't been helpful either. It seems that anyone who wants to run Cybersource with CF 9 would need to implement a .NET hack or use the COM libraries. In our case we decided not to upgrade to CF 9 until this problem is solved using the Java libraries.
            • 3. Re: Cybersource error on Coldfusion 9
              BKBK Adobe Community Professional & MVP
              I do indeed believe Coldfusion 9 introduces JARs containing new RSA libraries that conflict with the Cybersource code. It is likely that Cybersource has to update its libraries.
              I would send the error stack trace to Cybersource Support, explaining that the error is so severe it makes their product unusable. That should get them interested. After all, their name features in the stack trace.
              • 4. Re: Cybersource error on Coldfusion 9
                jmh2006
                Has anyone found a solution to this? I'm going in circles with Cybersource and they cannot tell me anything. They cannot even say which versions of CF they support but clearly the issue here is they do not support Coldfusion 9.
                • 5. Re: Cybersource error on Coldfusion 9
                  -==cfSearching==- Level 4
                  Can someone running CF9 try a test for me on a _development_ box.
                  Put the following jars in  WEB-INF\lib and restart. Run the basic checkout.cfm example.
                  cybs-cfm.jar
                  cybsclients15.jar
                  cybssecurity.jar
                  xercesImpl.jar **
                  xalan.jar **
                  ** Note: Use the versions provided by cybersource
                  • 6. Re: Cybersource error on Coldfusion 9
                    Adam Cameron. Level 5
                    What, you mean the stuff one can download from here:
                    http://apps.cybersource.com/cgi-bin/pages/dev_kits.cgi?kit=Java/All_Platforms ?
                    checkout.cfm ran fine... but then again it's just a form.  checkout2.cfm errors with:
                    Object Instantiation Exception.
                    Class not found: CyberSource
                    This is a bit odd, because it is there in cybs-cfm.jar.
                    Still... I don't know exactly what your expectations are of this test you're asking people to run...?
                    Adam
                    • 7. Re: Cybersource error on Coldfusion 9
                      Yep, the Simple Order API. My request was really directed to others in the thread already with familiar with the setup and issues. That and lack of sleep account for the glaring absence of details. But thanks for testing it with so little information to go on.
                      I  was trying to get cybersource working w/Tomcat 6 and was also  experiencing problems.  Adding all five jars (not just four) to  WEB-INF\lib seemed to resolve it.  I was curious if that change had any impact  on other configurations.  As presumably, the majority of people are not  using Tomcat.
                      ClassNotFoundException or NoClassDefFoundError?  NoClassDefFoundError usually means the class loader is having a problem  loading the class's "definition" for some reason, not that it cannot  find the physical class. I was receiving a lot of  NoClassDefFoundError's at first. But since cybersource and CF seem to share  several libraries (rsa, xalan and xerces) I was not really surprised.
                      Anyway, I finally caved in and installed a fresh copy of CF9 + built-in web server this morning. Lo-and-behold installing the jars exactly as described in the readme file worked.  Explicitly adding the jars to the java.class.path in jvm.config seemed to be the critical difference.  For what it is worth, here is what I ended up with.
                      {cf_root}\WEB-INF\lib:
                      cybs-cfm.jar
                      cybsclients15.jar
                      cybssecurity.jar
                      xercesImpl.jar
                      jvm.config snippet (abs. paths for clarity)
                      # JVM classpath
                      java.class.path={application.home}/servers/lib,{application.home}/../lib/macromedia_driver s.jar,{application.home}/lib/cfmx_mbean.jar,{application.home}/../lib/oosdk/classes,{appli cation.home}/../lib/oosdk/lib,{application.home}/lib,C:/dev/ColdFusion9/wwwroot/WEB-INF/li b/cybs-cfm.jar,C:/dev/ColdFusion9/wwwroot/WEB-INF/lib/cybsclients15.jar,C:/dev/ColdFusion9 /wwwroot/WEB-INF/lib/cybssecurity.jar,C:/dev/ColdFusion9/wwwroot/WEB-INF/lib/xercesImpl.ja r
                      Message was edited by: -==cfSearching==-
                      1 person found this helpful
                      • 8. Re: Cybersource error on Coldfusion 9
                        ... w/Tomcat 6 ...Adding all five jars (not just four) to  WEB-INF\lib seemed to resolve it.
                        BTW: Being a relative Tomcat novice, I am not sure that was the right way to go. Just that it seems to be working so far.
                        • 9. Re: Cybersource error on Coldfusion 9
                          EstebanD Level 1
                          This seems to be working. I read instructions but failed to follow these:
                          To add the CyberSource jar files to the CLASSPATH used by ColdFusion, edit the
                          file <coldfusion_dir>/runtime/bin/jvm.config and append the full path of the
                          following jar files to the value of "java.class.path":
                          We have been using cybersource libraries on CF 7 for over a year setting the class path in the "ColdFusion Class Path" box in the CF Administrator.
                          We will further test it before concluding is safe for production.
                          Thank you "cf searching"
                          • 10. Re: Cybersource error on Coldfusion 9
                            Cold Drink
                            I'm also having a problem getting Coldfusion 9 and the Cybersource API to work together.  I tried adding the 4 jars to the WEB_INF folder under Coldfusion as mentioned in this thread but its still not working.  Cybersource support basically said I'm on my own with this.  I see the following in the coldfusion-event log:
                            On CF Startup:
                            error ROOT CAUSE:
                                at com.rsa.certj.CertJ.<init>(Unknown Source)
                                at com.cybersource.security.SecurityContextJava.<init>(SecurityContextJava.java:155)
                                at com.cybersource.ws.client.Signature.<clinit>(Signature.java:39)
                                at CyberSource.runTransaction(CyberSource.java:32)
                                at cfcheckout22ecfm959397778.runPage(C:\cybersource\simapi-java-5.0.2\coldfusion\samples\nvp \checkout2.cfm:33)
                                at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:231)
                                at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:416)
                                at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
                                at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:363)
                                at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:48)
                                at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)
                                at coldfusion.filter.PathFilter.invoke(PathFilter.java:87)
                                at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70)
                                at coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:74)
                                at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8)
                                at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
                                at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46)
                                at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
                                at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
                                at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:53)
                                at coldfusion.filter.RequestThrottleFilter.invoke(RequestThrottleFilter.java:126)
                                at coldfusion.CfmServlet.service(CfmServlet.java:200)
                                at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
                                at jrun.servlet.FilterChain.doFilter(FilterChain.java:86)
                                at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42 )
                                at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
                                at jrun.servlet.FilterChain.doFilter(FilterChain.java:94)
                                at jrun.servlet.FilterChain.service(FilterChain.java:101)
                                at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106)
                                at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
                                at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:286)
                                at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543)
                                at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:203)
                                at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:320)
                                at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
                                at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:266)
                                at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
                            javax.servlet.ServletException: ROOT CAUSE:
                                at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:70 )
                            On Submission:
                            java.lang.NoClassDefFoundError: Could not initialize class com.cybersource.ws.client.Signature
                            I'm using the JVM that came with Cybersource under ColdFusion9/runtime/jre.  Should I be using a different JVM?  Everything was working fine under CF8 its just when we upgraded to CF9 that we hit a brick wall.  I'm on Windows Server 2003.
                            Anyone else get Cybersource API working with Coldfusion 9?
                            • 11. Re: Cybersource error on Coldfusion 9
                              jmh2006 Level 1
                              There is another .jar file (jsafeFIPS.jar) that you need to delete (and hope its not important) from the CF9 install. We got it working in a test environment but haven't done it in production since we wonder if the kludgy fix will cause other issues.  If Cybersource has decided not to support ColdFusion any longer the fix may be to get rid of Cybersource or run Cybersource from a server with CF7 or CF8.
                              • 12. Re: Cybersource error on Coldfusion 9
                                jmh2006 Level 1
                                Here is some info on the .jar file I mentioned (jsafeFIPS.jar):
                                This jar file  implements RSA standards for FIPS compliance. I am not sure what cold fusion is  using it for.
                                Let us know how it goes.
                                • 13. Re: Cybersource error on Coldfusion 9
                                  EstebanD Level 1
                                  We have it working on 9.01 without doing any changes or deleting any libraries from the original coldfusion installation.
                                  Our environment is:
                                  • Windows 2008R2 x64.
                                  • Using IIS.
                                  • IIS application pool running 32 bits.
                                  • Coldfusion 9.01 installed as 32 bits.
                                  • We choose to put cybersource libraries in C:/ColdFusion9/cfx/java
                                  Things to keep in mind when installing Cybersource under the previous environment.
                                  • Cybersource libraries location is not relevant
                                  • You don't need to delete or update any CF library. It works with the original installation.
                                  • CF MUST be 32 bits.
                                  • IIS Application Pool MUST be in 32bits.
                                  • The most important.. Set the cybersource library paths in C:\ColdFusion9\runtime\bin\jvm.config
                                  • In jvm.config SET (careful the paths are for our environment only):
                                    # JVM classpath
                                    java.class.path={application.home}/servers/lib,{application.home}/../lib/macromedia_driver s.jar,{application.home}/lib/cfmx_mbean.jar,{application.home}/../lib/oosdk/classes,{appli cation.home}/../lib/oosdk/lib,{application.home}/lib,C:/ColdFusion9/cfx/java/cybsclients15 .jar,C:/ColdFusion9/cfx/java/cybssecurity.jar,C:/ColdFusion9/cfx/java/xercesImpl.jar,C:/Co ldFusion9/cfx/java/cybs-cfm.jar
                                  We have been using the mentioned configuration in production without issues.
                                  • 14. Re: Cybersource error on Coldfusion 9
                                    Cold Drink Level 1
                                    Thanks for the quick responses.  I tried removing jsafeFIPS.jar, restarted CF and got the following error:
                                    error ROOT CAUSE:
                                    So I put that file back then I downloaded the most recent java API from cybersource thinking that mght help.  Then I tried submitting with that (after making my key file path change, etc.) and I'm still getting the same error in the logs:
                                    error (JRun Service: ProxyService [jrun.servlet.jrpp.JRunProxyService@fde0d5]) JRunPRoxyServer.invokeRunnable:
                                    java.lang.IllegalStateException
                                    error ROOT CAUSE:
                                    I made sure the class paths were in jvm.config.  Our server originally had CF8 on it, which I uninstalled before installing CF9.  I'm not sure why that would be an issue though.  EstebanD, did you install CF9 on a brand new server or did your server have an earlier version of CF on that server at one point?
                                    It wish Cybersource was more help.
                                    • 15. Re: Cybersource error on Coldfusion 9
                                      Yes, that was the critical difference for me.
                                      • 16. Re: Cybersource error on Coldfusion 9
                                        EstebanD Level 1
                                        Try putting cybersource libraries on a different path like: C:/ColdFusion9/cfx/java and set  jvm.config accordingly.
                                        We did both installing over CF7 and fresh install both worked. Never tried CF8 to CF9.
                                        • 17. Re: Cybersource error on Coldfusion 9
                                          Cold Drink Level 1
                                          Apparently when you add items to the class path through the Administrator it puts the paths into the jvm.config file but puts them under jvm arguments instead of jvm classpath.  Is this a bug in CF9?  I don't know why it would add them to the arguments to vm.
                                          Anywho, that fixed it for me.  Thanks everyone for the help.
                                          • 18. Re: Cybersource error on Coldfusion 9
                                            Krullion
                                            How do you even add a path via the administrator. I have some docs that tell me:
                                            Add the absolute path to imagecr3.jar, in the installation directory, to your
                                            "ColdFusion Class Path" path in the CF Administrator. You will find this under "Server Settings",
                                            then "Java and JVM"
                                            and there is NO SUCH SETTING that I can see in the CF Admin.
                                            • 19. Re: Cybersource error on Coldfusion 9
                                              ilssac Level 5
                                              What version and edition of ColdFusion are you using?
                                              I also do not see a Java and JVM section on my ColdFusion.  I suspect it is because I am using the Enterprise - Multihome edition and this edition is set up as servers under a JRun4 java configuration rather then a JRun4 runtime inside a ColdFusion configuration which is what happens for the more common standard|stand-alone editions.
                                              As such, I suspect configuring JVM configurations is a more manual process of editing the appropiate files under the JRun4 directories as there are many more possible permutations in this type of setup.
                                              • 20. Re: Cybersource error on Coldfusion 9
                                                It should mention (somewhere..) that is for server configurations only. I believe multi server configurations have a separate tool for modifying the jvm settings (?).  Either way, the settings are stored in jvm.config. So you can always modify that file manually. But be sure to make a backup first. If you mess it up, your server might not start.
                                                • 21. Re: Cybersource error on Coldfusion 9
                                                  Krullion Level 1
                                                  Hi, thanks for the response guys.... I'm running:
                                                  Version        9,0,0,251028
                                                  Edition      Enterprise
                                                  And I have in fact tried modifying: C:\JRun4\bin\jvm.config
                                                  I just need to add a single jar file... and it strips out my slashes... so, by the time I see it in the CF admin (path/settings,  etc) it looks like:
                                                  C:JRun4serverslibimagecr3.jar;
                                                  Jason
                                                  • 22. Re: Cybersource error on Coldfusion 9
                                                    You need to escape the slashes "
                                                    ", or even better use "/" instead.
                                                    • 23. Re: Cybersource error on Coldfusion 9
                                                      Krullion Level 1
                                                      Thanks for the help... I need to clarify... between the spaces ad the escaping, I'm  a mess
                                                      Here is what I think I am wanting in the jvm.config file. How's this look to you?
                                                      java.class.path="C:"\"Program Files (x86)"\"Efflare"\"ImageCR3Service"
                                                      Thanks.
                                                      • 24. Re: Cybersource error on Coldfusion 9
                                                        I do not remember if you have to quote the spaces. But if you did, it would only be one set of quotes around the whole path.
                                                        I am not near an example at the moment. But try something like:
                                                        C:\\Program Files (x86)\\Efflare\\ImageCR3Service\\
                                                        ... or
                                                        C:/Program Files (x86)/Efflare/ImageCR3Service/
                                                        • 25. Re: Cybersource error on Coldfusion 9
                                                          Sorry, I forgot the forums tendency to reduce most email responses to complete gibberish.
                                                          I updated the previous response and restored it to its original meaning ;-)
                                                          • 26. Re: Cybersource error on Coldfusion 9
                                                            Krullion Level 1
                                                            Thx so much for your efforts to help.
                                                            • 27. Re: Cybersource error on Coldfusion 9
                                                              Fuuzio Bill
                                                              Has anyone got CyberSource working at all on 64-bit ColdFusion/Windows Server?  I am at the end of my rope here, and not sure what else to do... I've tried everything and that seems to be the only thing in conflict withe EstabanD's setup.  I am getting the "com.rsa.jsafe.CryptoJ.isFIPS140Compliant()Z" error.
                                                              • 28. Re: Cybersource error on Coldfusion 9
        Cold Drink Level 1
        I believe you need to use Cybersource's SOAP API for all 64bit OS.  I don't believe their Simple Order API works on 64bit, windows or linux.  I have SOAP running on 64 bit linux, and just create the xml and use cfhttp to post it to cybersource's server.  Let me know if you want me to PM the code.
        • 29. Re: Cybersource error on Coldfusion 9
        Fuuzio Bill Level 1
        That would be AWESOME!  Thanks!!
        you can reach me at brainboxbill at gmail.  Thanks!!
        -Bill
        • 30. Re: Cybersource error on Coldfusion 9
        Cold Drink Level 1
        I've had a bunch of requests for the code so I'm just going to post it all here.  It's a simple cfm module page that just builds the xml and cfhttps it.
        For the cfhttp call, use https://ics2wstest.ic3.com/commerce/1.x/transactionProcessor for test and https://ics2wstest.ic3.com/commerce/1.x/transactionProcessor for production.
        You create the merchant key through the cybersource business center and add that to the cybersource_soap.cfm along with your username.
        The SOAP call was modified from Ben Nadel's site, hence all of the comments in the cybersource_soap.cfm page.
        I had an issue with our server not trusting the cybersource url in the cfhttp call and got a 500 error.  If you run into that, pull up https://ics2wstest.ic3.com/commerce/1.x/transactionProcessor in Firefox and view page info go to Security - View Certificate - Details - then export the certificate.  Then import that into your keystore on your server.
        I'm open to any suggestions to improve the code.  It was one of those projects where I needed to find a way to get it up and running quickly and I haven't touched it since.  Here's the code:
        cybersource_soap.cfm page:
        <cfscript>
        if(not isdefined("attributes.action")) attributes.action = "create";
        if(not isdefined("attributes.merchantReferenceCode")) attributes.merchantReferenceCode = "";
        if(not isdefined("attributes.type")) attributes.type = "";//one-time credit card charge=0, monthly charge=1
        if(not isdefined("attributes.firstName")) attributes.firstName = "";//required
        if(not isdefined("attributes.lastName")) attributes.lastName = "";//required
        if(not isdefined("attributes.street1")) attributes.street1 = "";//required
        if(not isdefined("attributes.street2")) attributes.street2 = "";
        if(not isdefined("attributes.city")) attributes.city= "";//required
        if(not isdefined("attributes.state")) attributes.state = "";//required
        if(not isdefined("attributes.postalCode")) attributes.postalCode = "";//required
        if(not isdefined("attributes.country")) attributes.country = "";//required
        if(not isdefined("attributes.phoneNUmber")) attributes.phoneNumber = "";
        if(not isdefined("attributes.email")) attributes.email = "";//required
        if(not isdefined("attributes.grandTotalAmount")) attributes.grandTotalAmount = "";
        if(not isdefined("attributes.card_accountNumber")) attributes.card_accountNumber = "";//required
        if(not isdefined("attributes.card_expirationMonth")) attributes.card_expirationMonth = "";//required
        if(not isdefined("attributes.card_expirationYear")) attributes.card_expirationYear = "";//required
        if(not isdefined("attributes.card_type")) attributes.card_type = "";//required
        if(not isdefined("attributes.card_cvNumber")) attributes.card_cvNumber = "";//needed for authorization
        if(not isdefined("attributes.ccCaptureService_run")) attributes.ccCaptureService_run = "true";//required
        if(not isdefined("attributes.merchant")) attributes.merchant = "";
        if(not isdefined("attributes.subscription_title")) attributes.subscription_title = "";
        //subscription specific fields
        if(not isdefined("attributes.subscriptionInfo_frequency")) attributes.subscriptionInfo_frequency = "monthly";//required for subscription
        if(not isdefined("attributes.subscriptionInfo_amount")) attributes.subscriptionInfo_amount = "";//required for subscription FIELD:recurringSubscriptionInfo_amount
        if(not isdefined("attributes.subscriptionInfo_numberOfPayments")) attributes.subscriptionInfo_numberOfPayments = "0";//required for subscription FIELD:recurringSubscriptionInfo_numberOfPayments
        if(not isdefined("attributes.subscriptionInfo_startDate")) attributes.subscriptionInfo_startDate = "";//required for subscription FIELD:recurringSubscriptionInfo_startDate
        if(not isdefined("attributes.subscriptionID")) attributes.subscriptionID = "";
        //other fields
        if(not isdefined("attributes.merchantDefinedData_field1")) attributes.merchantDefinedData_field1 = "";
        if(not isdefined("attributes.merchantDefinedData_field2")) attributes.merchantDefinedData_field2 = "";
        if(not isdefined("attributes.merchantDefinedData_field3")) attributes.merchantDefinedData_field3 = "";
        if(not isdefined("attributes.merchantDefinedData_field4")) attributes.merchantDefinedData_field4 = "";
        if(not isdefined("attributes.merchantSecureData_field4")) attributes.merchantSecureData_field4 = "";
        if(not isdefined("attributes.comments")) attributes.comments = "";
        </cfscript>
        <cfset username = "[YOUR CYBERSOURCE USERNAME]">
        <cfset merchantKey = "[YOUR CYBERSOURCE MERCHANTKEY]">
        <!--- charge --->
        <cfset soapBody="<?xml version=""1.0"" encoding=""UTF-8""?>
        <soapenv:Envelope xmlns:soapenv=""http://schemas.xmlsoap.org/soap/envelope/"" xmlns:xsd=""http://www.w3.org/2001/XMLSchema"" xmlns:xsi=""http://www.w3.org/2001/XMLSchema-instance"">
        <soapenv:Header>
        <wsse:Security xmlns:wsse=""http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"" soapenv:mustUnderstand=""1"">
        <wsse:UsernameToken xmlns:wsu=""http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd"" wsu:Id=""UsernameToken-23894119"">
        <wsse:Username>#username#</wsse:Username>
        <wsse:Password Type=""http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0##Passwo rdText"">#merchantKey#</wsse:Password>
        </wsse:UsernameToken>
        </wsse:Security>
        </soapenv:Header>">
        <cfset soapBody = soapBody & "
        <soapenv:Body>
        <requestMessage xmlns=""urn:schemas-cybersource-com:transaction-data-1.58"">
        <merchantID>#username#</merchantID>
        <merchantReferenceCode>#attributes.merchantReferenceCode#</merchantReferenceCode>">
        <cfif attributes.action is "create" or  attributes.action is "recharge">
        <billTo>
        <firstName>#attributes.firstName#</firstName>
        <lastName>#attributes.lastName#</lastName>
        <street1>#attributes.street1#</street1>
        <city>#attributes.city#</city>
        <state>#attributes.state#</state>
        <postalCode>#attributes.postalCode#</postalCode>
        <country>#attributes.country#</country>
        <email>#attributes.email#</email>
        </billTo>">
        <cfif attributes.type EQ 0>
        <item id=""0"">
        <unitPrice>#attributes.grandTotalAmount#</unitPrice>
        <quantity>1</quantity>
        </item>">
        </cfif>
        <purchaseTotals>
        <currency>USD</currency>
        </purchaseTotals>
        <card>
        <accountNumber>#attributes.card_accountNumber#</accountNumber>
        <expirationMonth>#attributes.card_expirationMonth#</expirationMonth>
        <expirationYear>#attributes.card_expirationYear#</expirationYear>
        <cvNumber>#attributes.card_cvNumber#</cvNumber>
        <cardType>#attributes.card_type#</cardType>
        </card>">
        <cfif attributes.type EQ 1>
        <!--- subscription --->
        <subscription>
        <title>#attributes.subscription_title#</title>
        <paymentMethod>Credit Card</paymentMethod>
        </subscription>
        <recurringSubscriptionInfo>
        <subscriptionID>#attributes.merchantReferenceCode#</subscriptionID>
        <amount>#attributes.subscriptionInfo_amount#</amount>
        <numberOfPayments>#attributes.subscriptionInfo_numberOfPayments#</numberOfPayments>
        <automaticRenew>false</automaticRenew>
        <frequency>#attributes.subscriptionInfo_frequency#</frequency>
        <startDate>#attributes.subscriptionInfo_startDate#</startDate>
        </recurringSubscriptionInfo>">
        </cfif>
        <merchantDefinedData>
        <field1>#attributes.merchantDefinedData_field1#</field1>
        <field2>#attributes.merchantDefinedData_field2#</field2>
        <field3>#attributes.merchantDefinedData_field3#</field3>
        <field4>#attributes.merchantDefinedData_field4#</field4>
        </merchantDefinedData>">
        <cfif attributes.action EQ "recharge">
        <orderRequestToken>#attributes.requestToken#</orderRequestToken>">
        </cfif>
        <cfif attributes.type is 0>
        <ccAuthService run=""true"" />
        <ccCaptureService run=""true"" />">
        <cfelseif attributes.type EQ 1>
        <paySubscriptionCreateService run=""true"" />">
        </cfif>
        <cfelseif attributes.action is "credit">
        <!--- credit --->
        <purchaseTotals>
        <grandTotalAmount>#attributes.grandTotalAmount#</grandTotalAmount>
        </purchaseTotals>
        <ccCreditService run=""true"">
        <captureRequestID>#attributes.requestID#</captureRequestID>
        <captureRequestToken>#attributes.requestToken#</captureRequestToken>
        </ccCreditService>">
        <cfelseif attributes.action is "retrieve">
        <!--- retrieve subscription information --->
        <PaySubscriptionRetrieveService run=""true"" />
        <subscriptionID>#attributes.subscriptionID#</subscriptionID>
        </cfif>
        </requestMessage>
        </soapenv:Body>
        </soapenv:Envelope>">
        <!--- <cfsetting showdebugoutput="no">
        <cfcontent type="text/xml">
        <cfoutput>#trim(soapBody)#</cfoutput>
        <cfabort> --->
        <cfset objSecurity = createObject("java", "java.security.Security") />
        <cfset storeProvider = objSecurity.getProvider("JsafeJCE") />
        <cfset objSecurity.removeProvider("JsafeJCE") />
        Now that we have our SOAP body defined, we need to post it as
        a SOAP request to the website. Notice that
        when I POST the SOAP request, I am NOT required to append the
        "WSDL" flag to the target URL (this is only required when you
        actually want to get the web service definition).
        <cfhttp
        url="https://ics2wstest.ic3.com/commerce/1.x/transactionProcessor" method="post"  result="httpResponse">
        <cfhttpparam type="header" name="Content-Type" value="application/soap+xml; charset=utf-8">
        <cfhttpparam type="header" name="Content-Length" value="#len(soapBody)#">
        <cfhttpparam
        type="xml"
        value="#trim(soapBody)#"
        Most SOAP action require some sort of SOAP Action header
        to be used.--->
        <cfhttpparam
        type="header"
        name="SOAPAction"
        value="runTransaction"
        I typically use this header because CHTTP cannot handle
        GZIP encoding. This "no-compression" directive tells the
        server not to pass back GZIPed content.
        <cfhttpparam
        type="header"
        name="accept-encoding"
        value="no-compression"
        When posting the SOAP body, I use the CFHTTPParam type of
        XML. This does two things: it posts the XML as a the BODY
        and sets the mime-type to be XML.
        NOTE: Be sure to Trim() your XML since XML data cannot be
        parsed with leading whitespace.
        </cfhttp>
        <!--- <cfset objSecurity.insertProviderAt(storeProvider, 1) /> --->
        When the HTTP response comes back, our SOAP response will be
        in the FileContent atribute. SOAP always returns valid XML,
        even if there was an error (assuming the error was NOT in the
        communication, but rather in the data).
        <cfif find( "200", httpResponse.statusCode )>
        <!--- Parse the XML SOAP response. --->
        <cfset soapResponse = xmlParse( httpResponse.fileContent ) />
        <!--- Get reply nodes --->
        <cfset replyNodes = XmlSearch(#soapResponse#,"//*[ local-name() = 'replyMessage' ]")>
        <!--- <cfdump var="#replyNodes#"> --->
        <cfset reasonCode = replyNodes[1].XmlChildren[1].XmlText>
        <!--- Set caller variables --->
        <cfloop from="1" to="#arrayLen(replyNodes[1].XmlChildren)#" index="i">
        <cfset tempa = "#replyNodes[1].XmlChildren[i].XmlName#">
        <cfset tempa = rereplace(tempa,"c:","","one")>
        <cfset "#tempa#" = "#replyNodes[1].XmlChildren[i].XmlText#" >
        <cfset "caller.#tempa#" = evaluate(tempa)>
        <cfset "caller.#tempa#_#i#" = evaluate(tempa)>
        <!---  <cfoutput>#tempa#_#i# = #evaluate(tempa)#<br /></cfoutput>  --->
        </cfloop>
        Query for the response nodes using XPath. Because the
        SOAP XML document has name spaces, querying the document
        becomes a little funky. Rather than accessing the node
        name directly, we have to use its local-name().
        <cfset responseNodes = xmlSearch(
        soapResponse,
        "//*[ local-name() = 'Subscriber.AddAndResubscribeResult' ]"
        Once we have the response node, we can use our typical
        ColdFusion struct-style XML node access.
        <cfoutput>
        Code: #responseNodes[ 1 ].Code.xmlText#
        <br />
        Success: #responseNodes[ 1 ].Message.xmlText#
        </cfoutput>--->
        <cfelse>
        <cfoutput> #httpResponse.statusCode# <br />msg2: #httpResponse.fileContent#</cfoutput>
        </cfif>
        calling page:
        <cfmodule template="cybersource_soap.cfm" subscription_title="" action="create" type="0" merchantReferenceCode="[UNIQUE ID NUMBER PER TRANSACTION]" street1="#billing_address#" firstName="#trim(billing_firstname)#" lastname="#trim(billing_lastname)#" city="#trim(billing_city)#" state="#trim(billing_state)#" postalCode="#trim(billing_zip)#" country="#trim(billing_country)#" phoneNumber="#trim(billing_phone)#" email="#trim(billing_email)#" card_type="[MASTERCARD, VISA, ETC]" card_accountNumber="#trim(ccNum)#" card_expirationMonth="#ccExpireMonth#" card_expirationYear="#ccExpireYear#" card_cvNumber="#ccCVN#" grandTotalAmount="#grandTotalAmount#" comments="">
        <cfdump var="#variables#">
        • 31. Re: Cybersource error on Coldfusion 9
        Dakuwan
        I have tried your code, Cold Drink, but have been unsuccessful.
        I get this response in the calling page:
        500 Internal Server Error
        msg2:  2012-09-21T22:15:18.038Z   wsse:InvalidSecurity  Security Data : No WS-Security Header
        I have imported all of the SSL certs for Cybersource and have been able to connect to their server with a get request and see the page so know that the certificates is not the issue.
        Has anyone run into this and if so what was their solutions.
