Flash Live Media Encoder claims that it can encode video from a firewire connection. Does it also encode audio from the same firewire connection? I've been told that past versions encoded video only. Can someone clarify this for me? Thx.
1. You can either choose "audio" or "no audio" for audio options.
2. It is necessary to encode the audio and video through the firewire input because if you use video firewire and audio from soundcard there is going to be latency issues with the audio not synced up with the video. It gets worse over the length of the time of streaming.
Hope that helps.
I cannot get Windows or FME to even see the DV camera using i.Link. USB works fine, but not IEEE1994. Suggestions?
Windows XP Pro SP3. Sony DCR-TRV19. FME 3.x. Flash Media Interactive Server.
1. Is this a laptop you are using?
2. Do you have any video editing software that you could use to try and recognize the camera? This is only for troublshooting whether it's the comp or the software not recognizing your camera.
3. Do you have any wbcams that may be overriding the computer trying to locate a capture device?
Thanks for the reply.
I cannot locate the Sony editing software and will look for something. But this is a desktop with an integrated firewire port. When trying to use a Windows Hotfix it warns me that the driver is already current. No other devices are trying to use the camera.
Date: Tue, 3 Nov 2009 09:07:32 -0700
To: bobricci@hotmail.com
Subject: Flash Media Encoder & Firewire
