PSE 7 Problems Fixed in PSE 8
johnrellis Oct 11, 2009 8:27 AMSince PSE 6 was released, I’ve tracked all the reproducible bugs I’ve encountered and reported to Adobe. I’ve tested these problems in PSE 8 and listed the results below – problems that appear to have been fixed in PSE 8 are marked [F], and problems that remain unfixed are marked [U].
Overview
There’s good and bad news. Adobe has fixed a number of serious bugs in the Organizer, but it has left most unfixed, even though they’ve been present since at least version 6. Even worse, the two major features introduced in the PSE 8 Organizer, face tagging and the keyword-tags text box, have show-stopper problems. And even worse yet, Full Screen view is now painfully slow with large catalogs.
The most important fixes address serious problems with PSE’s handling of drives that were introduced in version 6. PSE now notices when a drive’s letter has changed, a problem that has bedeviled many users upgrading or rearranging their drives. Also, PSE now ignores the case of UNC pathnames (network drives), no longer creating duplicate volumes for the same network drive. Unfortunately, one serious bug remains: PSE still gets horribly confused when there are two drives with the same volume serial number, and it still doesn’t even issue a warning.
But many long-standing problem areas remain: The Map View is an unusable toy. The handling of metadata is riddled with bugs. Folder Location view shows the wrong contents of folders. Searching has numerous bugs making it clumsy and confusing.
Overall, of all the bugs I’ve reported, PSE 8 fixes 8 of 46 major ones and 8 of 28 minor ones:
| Major | Minor | |||
| Fixed | Unfixed | Fixed | Unfixed | |
| File Management and Tagging | 4 | 6 | - | 2 |
| Integration with Photoshop.com | 2 | 5 | - | - |
| Map View | - | 6 | - | - |
| Color Management | - | 1 | - | - |
| Metadata | - | 10 | 2 | 3 |
| Searching | - | 8 | - | 5 |
| User Interface | 1 | 1 | 5 | 9 |
| Slide Shows | 1 | 1 | - | - |
| Editor | - | - | 1 | 1 |
| Total | 8 | 38 | 8 | 20 |
I’ve reported all of these problems to Adobe. Almost all of them are in the Organizer. Based on all the reports on the forums, it appears that the Editor has far fewer problems than the Organizer. Perhaps that’s because the Editor shares the same code with the professional Photoshop, while the Organizer appears to be an orphaned consumer product whose development Adobe has moved offshore.
For reference, my computer is a midrange Vista laptop with a dual-core 1.9 GHz processor, 4 GB of memory, and a 7200 RPM disk (the same speed as desktop disks).
New Problems in PSE 8
[U] PSE 8 crashes or gets intolerably slow after using the new Keyword Tags text box a small number of times.
On my 4 GB Vista 32 system, PSE crashes after tagging 41 photos.
[U] If you use the new Keyword Tags text box to apply an existing tag name with a comma in it, PSE will silently create two new tags instead.
Apply the existing tag “San Francisco, CA” will create two new tags, “San Francisco” and “CA”.
[U] After applying a tag, the Keyword Tags text box loses keyboard focus and you need to mouse-click in the box again to enter another tag.
Forcing the use of the mouse defeats the purpose of the Keyword Tags text box, which is to make tagging much faster.
[U] The Find > Find People For Tagging command locks up the Organizer for about 30 seconds after you click Done (even if you haven’t made any changes), when using larger catalogs.
On a catalog with 10,000 thumbnails showing, the cursor spins for 30 seconds after clicking done. But you can work around this by doing a tag search or setting a date range to have only a small number of thumbnails showing before you invoke the command.
[U] In the Find > Find People For Tagging command, when you select Add Missing Person, you usually can’t resize the selection box by grabbing the lower-right or lower-center handles, which are the handles that most right-handed people are likely to use.
If you move the mouse very quickly so that it is over the photo before the selection box appears, you can usually resize the box with those handles. But you have to be very quick.
[U] The Find > Find People For Tagging command doesn’t do auto-complete on pre-existing People tags, making it very hard to use with existing catalogs.
I have over two hundred People tags in my catalog. Because the command doesn’t auto-complete on pre-exisiting People tags and will silently create new tags, and because I don’t remember exact spellings (that’s the point of auto-complete!), I found myself creating duplicate tags (e.g. “John Ellis” instead of “John R. Ellis”, “Bob Smith” instead of “Robert Smith”). It’s painful to clean up such a mess.
[U] Full Screen view (F11) is much slower than in PSE 7 on larger catalogs.
With a 14,000-file catalog and all thumbnails visible, PSE 7 takes 6 seconds to invoke F11, while PSE 8 takes 13 seconds. With just 20 thumbnails visible (e.g. when working on the most recent import batch), PSE 7 takes 1 second, while PSE 8 takes 7 seconds. This makes selecting the good and weeding out the bad significantly slower.
[U] PSE doesn’t remember the settings if you toggle the Full-Screen Quick Edit Panel and Quick Organize Panel to disappear completely.
On 4:3 displays, it’s desirable to hide the panels completely in full-screen view, so you see the entire image without the panels overlapping them (that’s the point of full-screen view, no?). But PSE forgets the toggle settings, even in the same session.
[U] The keyword tagging in the Quick Organize Panel doesn’t auto-complete tags you type, making it useless with more than a dozen or so tags.
It’s worse than useless, since it will silently create a new tag if you mistype the name of an existing one. And the “tag cloud” is a silly toy that doesn’t help with hundreds of tags.
Major Problems
[F] After reconnecting a file on a network drive, PSE will let you import the file a second time, failing to recognize it as a duplicate. The catalog is left in an inconsistent state, with two entries in the volume table for the network drive, one upper case and one lower case.
[F] The Reconnect command fails to reconnect when: you move your photos to a new drive, assign the drive the letter of the old drive to the new one, and leave both drives connected to your computer.
[F] If a hard drive containing photos in the catalog gets its drive letter reassigned by Windows, then the left-hand folder pane of Display > Folder Location view shows the old drive letter, not the new one, as containing the photos.
This sounds innocuous, but it led a user on the forums to select the wrong drive when dragging and dropping a folder, permanently deleting some files. This bug and the previous one with Reconnect had the same underlying cause – the Organizer didn’t update drive letters in its catalog. Fixed in PSE 8.
[F] The Restore Catalog command puts the wrong path into the restored catalog for folders whose name starts with the catalog name, and it will mark files in those folders as missing. For example if the catalog is named “houses”, and a folder containing photos in the catalog is named “houses photos”, files in the restored catalog will have the path “houses\ photos\” instead of “houses photos\”.
[U] Folder Location view shows incorrect folder contents when more than one keyword tag is selected in the Keyword Tags pane.
Based on reports on the forums, there appear to be other situations where Folder Location view shows incorrect folder contents, but they haven’t been easy to reproduce.
[U] The Organizer fails very ungracefully when two drives have the same volume serial number, e.g. because of the use of a disk-cloning utility.
I remain mystified that Adobe didn’t add the three lines of code that would have issued a warning when it discovered two drives with the same number. While most people will never encounter this, when it strikes someone, its symptoms are very mysterious (and a lot of people using cloning utilities).
[U] The conversion of a catalog from PSE 6 to PSE 8 doesn’t properly handle photos that are stored within the PSE 6 catalog folder (as occurs when PSE 6 was used to restore a catalog from a backup). As a result, it isn’t possible to save photos in version sets, and PSE 8 will create duplicate thumbnails in the Organizer for an edited file.
[U] File > Backup/Restore Catalog doesn’t backup and restore audio in slide shows.
[U] Using Folder Location view to move a folder containing hidden files imported in the catalog will silently fail to move the hidden files and will leave the unhidden files disconnected in the catalog.
[U] When converting a previous-version catalog whose photos are stored inside the catalog folder, as occurs when you’ve previously used File > Restore Catalog with New Location, PSE 8 needlessly copies all those photos. If you have a very large catalog, this will waste huge amounts of disk space; and if there isn’t enough disk space to do the copy, the conversion will fail instantly with a generic non-explanatory error message.
Minor Problems
[U] In File > Export, the Common Basename can no longer be empty, and a hyphen is added automatically, so you can no longer get files named 1.jpg, 2.jpg, etc.
You can get files named 1.jpg, 2.jpg, etc. but you can’t get files named p1.jpg, p2.jpg, etc. – a hyphen is still added in that case.
[U] Setting the Apply Metadata > Author or Copyright fields or the option Preserve Current Filename In XMP of the advanced options of the Photo Downloader causes duplicate files to be downloaded and imported.
Major problems
[F] If you you rename a file that’s synced with Photoshop.com, Photoshop.com doesn’t pick up the new name (important if you’re using Photoshop.com as a backup service).
[U] Photoshop.com shows an incorrect date/time taken for photos with unknown month, day, or time.
The date/time shows as the the first month/day/minute/second in that time period in UTC that then gets converted to local time; e.g. “7/2/2005” gets shown as “7/1/2005 5:00 PM” for a user in PDT.
[U] Photoshop.com doesn’t obey the EXIF Orientation metadata field and can show photos rotated incorrectly, e.g. if they were rotated with the PSE option Edit > Preferences > Files > Rotate JPEGs/TIFFs Using Orientation Metadata.
[U] Changes to the order of photos in a PSE album aren’t synced to Photoshop.com, and vice versa.
[U] Only the top photo in a version set is synced with Photoshop.com (so you can’t rely on Photoshop.com to backup version sets).
[U] When a stack is synced with Photoshop.com, all the photos in the stack are synced, but the fact that they were in a stack is lost (so you can’t rely on Photoshop.com to backup stacks).
Map View
Major Problems
[U] It takes 4 seconds to assign a keyword tag to a photo if there are 2,000 or more photos with map locations.
It takes 2 seconds with 1,000 photos, 6 seconds with 4000 photos, and 11 seconds with 8,000 photos, and 21 seconds with 12,000 photos.
[U] Map view is unusably slow with more than 8 - 10,000 mapped photos.
When I imported 12,000 photos (the size of my catalog) that had GPS locations, the Organizer crashed a number of times when I tried to zoom and pan the Map view. When I selected Limit Search to Map Area, PSE took over a minute to respond.
[U] Giving a map location to a tag assigned to hundreds of photos makes both the Keywords pane and the Map view unusably slow.
Giving a map location to a tag assigned to 1700 photos makes assigning any keyword tag to a photo very slow, 12 seconds. Searching on keyword tags and Show All each take 13 seconds.
[U] Removing the map push-pin of a tag assigned to hundreds of photos mistakenly tries to update the metadata of each photo, which can take tens of minutes and fill up your recycle bin.
The weird thing is that assigning a map location to the tag doesn’t try to write the metadata of files with that tag.
[U] Moving map locations always fails, silently (too bad if you want to record backcountry locations not namable via a place name).
[U] If a photo with GPS coordinates is imported, it doesn’t show as a red push-pin on the map.
Scrolling the map or restarting the Organizer causes the pin to appear.
Color Management
Major Problems
[U] The Organizer considers photos produced by cameras set to the color space Adobe RGB as untagged with a color profile, showing their colors incorrectly.
Metadata
Major Problems
[U] The File > Write Keyword Tag command doesn’t create or update .XMP sidecars for Nikon D300 or D80 .NEF raw files (but it does for Canon CR2 raw files).
The PSE 8 Write Keyword Tag command now gives a warning when you try to invoke it on a D300 .NEF raw file. Why PSE can write sidecars for Canon but not Nikon raw files is a mystery – it’s no harder to handle one than the other.
[U] File > Write Keyword Tags and Properties fails to write the map location (GPS coordinates) of TIFFs (tested with TIFFs produced by the PSE Editor and the Nikon Coolscan V, Nikon Coolscan 5000, and Epson 4490 scanners).
[U] File > Write Keyword Tags doesn’t write the map location (GPS coordinates) into the .xmp sidecar files of Nikon D80 or Canon G9 raw photos.
[U] The Organizer ignores correctly formatted EXIF GPS locations in some files that many other programs can read without trouble; this may be because the EXIF is encoded in little-endian byte order.
[U] New dates set by Edit > Adjust Date and Time sometimes get silently lost.
See http://www.johnrellis.com/psedbtool/photoshopelements-6-7-faq.htm#_Date/times_of_files for details and workarounds.
[U] Edit > Adjust Date and Time > Shift To New Starting Date And Time and > Shift By Set Number Of Hours writes the time in UTC rather than local time, as required by the standard, causing other tools to show the wrong date/time.
[U] In Thumbnail View, the Organizer incorrectly orders files that have unknown time. For example, it will show a file dated 12/25/1976 8:00 PM PST after a file dated 12/26/1976 (unknown time) on a computer in time zone PST.
[U] If you set a file's date/time fields to all unknown with Edit > Adjust Date And Time, the value of EXIF:DateTimeOriginal isn't cleared by File > Write Keyword Tag.
[U] Edit > Adjust Date and Time doesn’t properly handle US Daylight Savings Time when setting date/times many decades ago, e.g. October 5, 1961 12:00 PM.
[U] When setting the Organizer’s date/time for imported photos containing EXIF:DateTimeOriginal but not XMP:DateTimeOriginal, PSE 7 doesn’t properly handle US Daylight Savings Time in years prior to 2007, e.g. October 31, 2006 12:00 PM.
Minor Problems
[F] The Properties – Metadata window shows the wrong value for Date Time Original when the month, day, or time is unknown.
[F] When you save an edited photo as a new file but not in a version set, the edited version picks up the date/time and caption of the original but not the keyword tags, star rating, or notes.
Now, the edited version picks up date/time, caption, notes, and keyword tags, but not the star rating, which could be charitably interpreted as a plausible design decision.
[U] Deselecting the option Use “Last Modified” Date If EXIF Date Is Not Found does not work – the last-modified date is always used for an imported file that doesn’t contain an EXIF date.
[U] Edit > Adjust Date and Time applied to a file with time “unknown” decrements the date by one day.
[U] With the Import EXIF Caption option turned off, captions pre-existing in a file’s EXIF:ImageDescription metadata field reappear in the Organizer after invoking the Full Editor.
Searching
Major Problems
[U] The timeline doesn’t correctly display date ranges spanning many years.
[U] Using the Keyword Tags pane, you can no longer exclude a parent category from a search, e.g. exclude all photos tagged with any tag in the People category.
The User Guide gives two examples of how to use category exclusion that just don’t work in PSE 6, 7, or 8. Interestingly, you can almost work around this by doing a text search of “not <category tag>”, e.g. “not People”. But this will also exclude photos that happen to have the word “people” in their filenames, captions, or notes, probably not what you want. You can also use the text query “not tag:<category tag>”, .e.g. “not tag:places”, but this will exclude all tags containing “places” as part of their name – there is no way to get an exact match of a tag name.
[U] Find > By History > Imported On sorts the photo dates alphabetically, rather than by date/time.
When the results first display, they are now sorted by Imported From then (correctly) by Date/Time. However, if you click on the Date/Time column header to sort by that column, the dates are sorted alphabetically (incorrectly).
[U] Find > By History > Imported On takes a couple of minutes on a large catalog, making the command almost useless.
[U] Find > By History > Imported On shows a scary message “Deleting Keyword Tags” that is apparently harmless.
[U] Searching with the Find Bar for “1 star and lower” doesn’t show photos with 0 stars.
Find > By Details > Rating Is Lower Than 1 Star does work.
[U] Searching for “0 stars only” doesn’t work for photos in a catalog converted from PSE 5.
[U] Searching with date ranges doesn’t properly handle time “unknown”.
Minor Problems
[U] The Show All button sometimes doesn’t appear if you quickly type a query into the Search text box and hit Enter.
[U] Setting a date range and then excluding two tags from the search clears the date range.
[U] Show All doesn’t clear a date range set by Find > Set Date Range (can be very confusing).
[U] Save Search Criteria As Smart Album isn’t available if a date range has been set but no other search criteria have been.
[U] When searching, you can exclude a keyword tag and then include an album, but you can’t do it in the other order.
User Interface
Major Problems
[?] On 1024x768 displays, and sometimes at higher resolutions, the Editor Print window is positioned to perfectly obscure the scroll bar of the drop-down list of printer profiles, leading people to think their printer’s profiles aren’t available.
I can’t reproduce this in PSE 8. The Editor’s Print dialog is all rearranged. But this bug struck some people and not others, so it may be still lurking.
[U] The menu bars don’t display if you have changed the screen DPI to be larger than 96 (as many people do on today’s ubiquitous high-res displays).
Adobe should be embarrassed about this, given that more and more computers are shipping preconfigured with higher DPIs. See http://www.johnrellis.com/psedbtool/photoshopelements-6-7-faq.htm#The_Organizers_Menu_Bar_ doesnt_show for a workaround.
Minor Problems
[F] Copying a paragraph from Microsoft Word and pasting it into the Notes field of a keyword tag causes some of the spaces between words to be deleted.
[F] In the full Editor, if at least one open photo is minimized to the Project Bin, Ctrl-Tab no longer cycles through the open windows.
[F] The Editor window can’t be resized the standard Windows way by grabbing any edge, just the lower-right corner.
Well, almost – you can grab the left, right, and bottom edges but not the top.
[F] Alt doesn’t underline the shortcut letters of top-level menu items in the Full Editor (but it does in the Organizer).
Both the Editor and Organizer don’t show the underline until you let up on the Alt key, whereas other Windows program show the underline when you first press the Alt key.
[F] The width of the Editor's Palette Bin can't be adjusted by dragging the left edge, as you can with all the other similar panes (Project Bin, Organizer Bin, Map View).
[U] In the Properties window of Full Screen mode, if you click in the Notes field and do Ctrl-A to select all the text, then click in the Caption field and do Ctrl-A to select its text, the notes remain highlighted.
[U] In the Organizer, Help > System Info reports the wrong amount for “Built-in Memory” on computers with more than 2GB of installed memory. (The command reports the correct amount in the Editor.)
[U] The setting of View > Show Borders Around Thumbnails isn’t remembered after you restart PSE.
[U] Ctrl-A to select all text doesn’t work in the text fields of the Properties window.
Interestingly, you can use ctrl-A in the text fields of the full-screen mode Properties window.
[U] Dialogs in the Editor sometimes bounce back when you try to move them.
[U] Dates are shown by Display > Import Batch as 2\20\2008 rather than 2/20/2008.
[U] In Create > Slide Show > Slide Show Preferences dialog, you can't use backspace or delete to clear the text in the Static and Transition Duration fields -- you need to select the text and then type over the selection (non-standard Windows behavior).
[U] Escape doesn’t close the full-screen-mode Properties dialog.
[U] You can’t use the Windows Explorer Tile command to tile the PSE Organizer and Editor windows.
The Editor can now be tiled by Windows Explorer and other window managers, but the Organizer still can’t.
Slide Shows
Major Problems
[F] The duration of a video clip included in a Slide Show is set to the default duration, not the length of the video clip, and right-click Edit Duration doesn’t change the clip’s duration.
PSE now sets the duration to the length of the clip. You can’t edit the duration, though – you can invoke Edit Duration, but PSE ignores the new value.
[U] An audio caption attached to a photo isn’t imported into a slide show even though the option Include Audio Captions as Narration is selected.
For an individual slide, you can give the Use Existing Audio Caption command to import that photo’s existing audio caption.
Editor
Minor Problems
[F] The Editor crashes if you invoke Quick Fix and use just one Touch Up tool (e.g. Whiten Teeth) and then save the file (but your changes are correctly saved).
[U] The File > Save For Web command doesn’t remember the last settings (e.g. file format and quality) after your restart the Editor.
For a workaround, see http://www.johnrellis.com/psedbtool/photoshopelements-6-7-faq.htm#_Allow_Save_For.
