Is it possible to use a custom config with fckeditor thats
built into cf8? I need to have the ability to have multiple configs
for different applications. I need to do this like you did before
they integrated it:
Ok, but will this still use the editor that is packaged with
cf8 or does your answer indicate me running a stand alone copy of
fck? I just want to eliminate me having multiple copies of fck for
each site that I need to use it I just want to use one copy
globally.
Then I must be wrong.. Sorry for my misunderstanding..
But if your intention is really meant for styling, then you
can edit your "fckstyles.xml" by adding newer classes for various
application running in your server..
Mainly it will be toolbar differences, which is not so much a
problem. But where it seems to be a problem is when I need to
change tabs and dialog settings for image uploads and such. As it
is, changing the options in /cfide/scripts/ajax/FCKeditor will not
work for me as it will affect every instance that I am running.
<cftextarea> would benefit greatly with an attribute called
'customconfig' so that you could do your own myconfig.js.
