I've downloaded and installed RH8 but can only launch it from the "New Task" button on the Task Manager. I've tried the Start/Run feature copying the exact same file/path (C:\Program Files\Adobe\Adobe RoboHelp 8\RoboHTML\RoboHTML.exe) as the one on the Task Manager that works....but nothing happens. I've tried clicking the RH8 HTML icon, but no luck and I've also tried locating the exe file on the RH directory and double-clicking....still no luck.
This isn't a big deal, but I'd like to know what's so different about the Task Manager.
Just to save some time for the smart people, I'll ask for a little more information:
1. What version of Windows are you using?
2. What are your permissions? Are you still an administrator for this PC? (I know you had Administrator privileges at one time, because you used them to install RH8.)
I don't think anything is special about Task Manager per se, but there might be something off about your install. Or some overzealous security software might be restricting your ability to run .exe files from the other locations. It's certainly not normal behavior!
I'm sure the gurus on this forum will have better advice, but if you can provide the info above, it may help you get a more useful answer sooner.
e
Thanks for your help.....I'm using Windows XP Professional and, yes, I still have Admin privileges....I've tried to repair/re-install at least 3 times, but I still get the same result.
P
Curieus...
Can you start RoboHelp from the cmd or from a .bat file? (Not a command line option to create output, but start the executable from windows cmd)
Greet,
Willam
Can you tell me how to do this? Thanks! P
From CMD:
Go to Start, Run, CMD, press ENTER
Go to the installation directory of RoboHelp, such as: C:\Program Files\Adobe\Adobe RoboHelp 7\RoboHTML
Type: 'C:' (without quotes) press ENTER
Type: 'cd Program Files\Adobe\Adobe RoboHelp 8\RoboHTML'
Start RoboHelp HTML
Type: 'RoboHTML.exe' press ENTER
From .bat
Create a new file in notepad and save with a .bat extension.
Paste the following code (change the drive and the path when nessecary, and include the double quotes):
C:
cd "C:\Program Files\Adobe\Adobe RoboHelp 8\RoboHTML\"
start RoboHtml.exe
Save again and run by double clicking the .bat file
Greet,
Willam
CMD:
Couldn't get past step 2..get error (see attachment)
.BAT: Nothing happens.
There's no attachement to your post. Please attach through the forum, not per mail.
Greet,
Willam
I see, my bad:
Do the following:
Type 'C:' press ENTER
Type 'cd\' press ENTER
- You should now be in C:\>
Type 'cd Program Files\Adobe\Adobe RoboHelp 8\RoboHTML' press ENTER
Type 'RoboHTML.exe' and press ENTER
This should do it.
Greet,
Willam
Instead of RoboHelpHTML.exe, use RoboHTML.exe.
The system can't find the file, since the file you want to run is called RoboHTML.exe
Greet,
Willam
Hi there
A small request please. I'm not sure why everyone seems to opt for the attachment option for images. It's a lot more helpful if you insert them inline using the Camera icon.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
Thanks, Rick...will do in the future...
Hmmm,
When RoboHelp won't start, do you see the process RoboHTML.exe in the process tab of the task manager? Close all running instances of RoboHelp before checking this.
Can you try the following:
- Create a new shortcut on your desktop, and let it point to RoboHTML.exe, just like a regular shortcut.
- Now go to the properties of your shortcut (right click | Properties) and go to the tab Shortcut (If i translate correct)
- Go to 'Start in' and set the directory "C:\Windows\System32"
- Click OK and try to run RoboHelp from the shortcut.
Greet,
Willam
Only when I run RH from the "New Task" option in Task Manager does it display on the Process Tab.
I tried creating the new shortcut and changing the Start directory, but nothing happens when I run it....so sorry...are you ready to give up yet?
Thanks for your patience and perserverance!
P
Hmmm,
What happens if you click Start, Run and run the following command: "C:\Program Files\Adobe\Adobe RoboHelp 8\RoboHTML\RoboHtml.exe" (no quotes)?
Greet,
Willam
Nothing happens...no Robohtml.exe in the Task Manager
This is getting a long shot,
Perhaps your user profile has been corrupted in some way. If someone else logs into your PC, can he start RoboHelp 'the normal way'?
Greet,
Willam
No
I'm all out of ideas, except for a fresh clean Windows install That's all I can think off, sorry.
Greet,
Willam
Thanks so much for trying, Willam!
