I need system sounds and microphone inputs to be recorded at the same time. Renarrating after one audio input is recorded isn't an option, as I need to capture a conversation between two people in an online enviroment.
Any suggestions would be greatly appreciated. Thanks.
Hi there
If your only goal is to mix system sounds and the mic, you might also wish to obtain some simple cables from a place such as Radio Shack. You could insert one cable that runs from the speaker out or headphones jack into a Y cable that has two inputs. You would then connect the mic to the other input and then connect the other end into the Mic input of the PC.
You need to investigate using a mixer. With a mixer, you have one connection between the Mixer and the PC and you then connect a variety of input sources to the mixer.
Use Google and search the web for mixers. I think you can find some for $100 or so.
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
