Have you overridden this in your single source layout properties? You can specify the format of breadcrumbs there as well.
Read the RoboColum(n) for a tips, tricks and musings on the Technical Communication Suite products.
Thanks Colum for your reply.
I have not changed any settings in single source layout properties. But looks like if I define any settings there, it will apply those.
Please advise what should I select in single source layout properties, so that it takes styles from .css file and not from single source layout properties.
Your help is apprecaited.
Have you tried applying the "Apply to all Topics" option in the single source layout and selecting your style sheet in the CSS dropdown?
Hi Colum,
I have tried doing that, but no success.
Is there anything else I can do?
Where have you breadcrumbs defined? You may want to read this before answering.
