Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
No credential found with alias
Avatar
Former Community Member
Hello,
I am using livecycle 8.2 on WindowsXP with Jboss (trial turnkey installation).
When invoking process from Workbench, which contains service [Apply Usage Rights] I am receiving following Exception:
2009-10-14 10:13:20,429 ERROR [com.adobe.livecycle.readerextensions.CredentialsHelper] ALC-RES-001-002: No credential found with alias [0005859_EXP_12312009].
com.adobe.truststore.errors.exception.TrustStoreAuthorizationException: Insufficient Privileges -- (error code bin: 0, hex: 0x0)
2009-10-14 10:13:20,429 ERROR [com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker] An exception was thrown with name com.adobe.livecycle.readerextensions.client.exceptions.ReaderExtensionsException message:ALC-RES-001-002: No credential found with alias [0005859_EXP_12312009]. while invoking service ReaderExtensionsService and operation applyUsageRights and no fault routes were found to be configured.
I verified that I have "0005859_EXP_12312009" label in Trust store -> local credentials. In a fact I tried also original "CREDENTIALS" label (which was available after instalation). When I am using http://<livecycleserver>:8080/ReaderExtensions/ flash application, reader-extensions works without errors, using the same private credential labels (CREDENTIALS, 0005859_EXP_12312009).
Is there anyone, who have had the same experience ?
I will appreciate every advice.
Thanks.
1 Accepted Solution
Avatar
Correct answer by
It looks like a security error related to the permissions of the user or group that is running the service. The service must have a security definition that includes a user that has the privilege to run Reader Extensions.
Steve
Avatar
Correct answer by
Steve
Avatar
Thank You very much Steve.
I am still in very beginning with LiveCycle, but this was my stupid mistake. When I test the service to be run under superAdministrator, it works fine.
Thanks.
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
