Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
How to read Xml Node in DDX process
Avatar
Level 1
Hi All,
I face problem when reading xml node with DDX process.
(this is more a syntax problem)
On a workbench process, I want insert header in a pdf file with some datas coming from Xml variable
So I use Invoke DDX process and try to use External Data Url but without success.
(this is ok for variable) :
<?xml version="1.0" encoding="UTF-8"?>
<DDX xmlns="http://ns.adobe.com/DDX/1.0/">
    <PDF result="outDoc">
        <PDF source="inDoc">
          <Header>
              <Right><StyledText><p><String url="process:///process_data/in_xml?serialize(in_xml/a/b)"/></p></StyledText></Right>
          </Header>
        </PDF>
    </PDF>
</DDX>
I tried different thing, without success :
     <String url="process:///process_data/in_xml/a/b)"/>
Somebody could help me ?
Thank you.
Avatar
Level 1
I resolve a part of my problem with the current syntax:
<String url="process:///?serialize(/process_data/in_xml/a/b)"/>
Xml file is :
<a>
    <b>Test b</b>
    <c>Test c</c>
</a>
so the 'full' ddx file :
          <Header>
              <Right><StyledText><p color="red" font-size="9pt" font-family="Arial" ><String url="process:///?serialize(/process_data/in_xml/a/b)"/></p></StyledText></Right>
          </Header>
        </PDF>
    </PDF>
</DDX>
But the result is "<b>Test b</b>" and not just "Test b"
any idea ?
Avatar
Level 1
If this can help somebody :
          <Header>
              <Right><StyledText><p><String url="process:///?substring-before(substring-after(serialize(/process_data/in_xml/a/b),'&gt;'),'&lt;')"/></p></StyledText></Right>
          </Header>
        </PDF>
    </PDF>
</DDX>
Is there easiest way ?
