Hi All,
I face problem when reading xml node with DDX process.
(this is more a syntax problem)
On a workbench process, I want insert header in a pdf file with some datas coming from Xml variable
So I use Invoke DDX process and try to use External Data Url but without success.
(this is ok for variable) :
<?xml version="1.0" encoding="UTF-8"?>
<DDX xmlns="http://ns.adobe.com/DDX/1.0/">
<PDF result="outDoc">
<PDF source="inDoc">
<Header>
<Right><StyledText><p><String url="process:///process_data/in_xml?serialize(in_xml/a/b)"/></p></StyledText></Right>
</Header>
</PDF>
</PDF>
</DDX>
I tried different thing, without success :
<String url="process:///process_data/in_xml/a/b)"/>
Somebody could help me ?
Thank you.
Total Likes
I resolve a part of my problem with the current syntax:
<String url="process:///?serialize(/process_data/in_xml/a/b)"/>
Xml file is :
<a>
<b>Test b</b>
<c>Test c</c>
</a>
so the 'full' ddx file :
<Header>
<Right><StyledText><p color="red" font-size="9pt" font-family="Arial" ><String url="process:///?serialize(/process_data/in_xml/a/b)"/></p></StyledText></Right>
</Header>
</PDF>
</PDF>
</DDX>
But the result is "<b>Test b</b>" and not just "Test b"
any idea ?
Total Likes
If this can help somebody :
<Header>
<Right><StyledText><p><String url="process:///?substring-before(substring-after(serialize(/process_data/in_xml/a/b),'>'),'<')"/></p></StyledText></Right>
</Header>
</PDF>
</PDF>
</DDX>
Is there easiest way ?
Total Likes
