1 Reply Latest reply on Jun 22, 2010 5:44 PM by howaboutthisisthisok
    Not able to install Air 1.5 on Snow Leopard
    grimsy
      Hi.
      I have some problems installing Air 1.5 on OS X 10.6. The installer completes the installation successfully, but when I click on "FInish" I get a new window with this error msg:
      An error occurred while installing Adobe AIR. Installation may not be allowed by your administrator. Please contact your administrator.
      I have admin rights on the machine. I tried to repair disk permissions using the disk utility, but that did not help :-(
      I also tried to make changes in the language&text prefs (saw several others tried this with luck....), but that did not help either......
      No previous installations of Air was on the machine, this is a new os installation more or less.
      Here is the .airinstall.log:
      Performing runtime install
      UI SWF load is complete
      UI initialized
      starting user confirmation
      Version of this installer: 1.5.2.8870
      Installation type: new
      starting elevated install
      subinstaller: starting install
      subinstaller: Scheduling runtime installation operations
      subinstaller: Beginning runtime installation
      subinstaller: Beginning install
      subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
      subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
      subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/file1
      subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
      subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app
      subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/file2
      subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/Frameworks
      subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
      subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
      subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/file3
      subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
      subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
      subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
      subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
      subinstaller: Execution complete; beginning commit phase
      subinstaller: Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/file1
      subinstaller: Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/file2
      subinstaller: Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/file3
      subinstaller: Commit complete
      subinstaller: install complete
      subinstaller: begin quitting
      Elevated install completed
      Elevated install failed (3003)
      runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Error #3003" errorID=3003]
      begin quitting
      error in stateQuitting: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Error #3001" errorID=3001]
      Please help before I loose it , hehe....
