I have been working with Adobe (case #181204271) for over two weeks now to resolve this issue. I was wondering if anyone might be able to suggest some troubleshooting procedures. I have a compiled Flash Help file that I need to update for an upcoming release of our proprietary software. Two weeks ago, I was able to open the working xpj file although RoboHelp was very slow in responding when attempting to open topics for updating. Adobe advised me to replace the iWYSIWYG.dll file. This did resolve the issue with the slow response of the application and I was able to update my project successfully. Since that time, additional revisions are needed to the project before we publish the flash help file to our web server. I am no longer able to open the xpj file.
Not only am I unable to open the desired project, can’t I open the xpj file for all old projects and the sample project that comes with RoboHelp. I have been instructed by Adobe to uninstall the application and reinstall under a different user profile with administrative rights. In doing this, I received Active X error messages. i can notcreate a new project in RoboHelp 7 for HTML either. I was advised by Adobe to deleted the xpj and cpd files and try to edit the hhp file. I am also unable to open the hhp file. Any suggestions are greatly appreciated! Thank you!
I am surprised that Support did not ask you to apply the three patches that were issued for Version 7, I don't think they will fix this problem but that cannot be ruled out and is the first thing to try. Please try that and post back.
Also see Item 40 in Snippets on my site. It relates to an old version but could still be the cause.
I am assuming that at least Clownfish is on a local drive and that we can rule out the project being on a network as a cause. Usually that would manifest itself in a different way in any case.
What error do you get when opening from the HHP file? Please insert any more images using the camera icon so that we can see them within the post.
Have you tried with anti virus software and firewall disabled? Only do that with IT permission and disconnected from the internet.
Thanks for your suggestions. I only found one patch to apply:
Adobe RoboHelp 7.0.1 - English, French, German, and Japanese
REgarding item 40 on your Snippets, when I atempt to open RoboHelp for Word, I get an error mesage that reads RoboHElp explorer is unable to start Word. I have uninstalled RoboHelp X5 and the upgrade to RoboHelp 7 and reinstalled both. Also had IT provide me with a new profile. Unfortunately, these steps did not resolve the issue of being unable to open xpj files.
Yes, Clownfish project and the project I am attempting to open are on my local drive not on a network drive.
When trying to open the hhp file, I get the following error message:
error message when uninstalling and reinstalling and trying to create a new project:
error when deleted xpj and cpd files and attempting to edit the hhp file
How did you search for the patches? If you used Help > Updates it should now find a second one and then a third. If you went to the download site, you should have found all three. However, as I said earlier, I think this is much deeper and now that RH for Word is not functioning, that is confirmed.
I think the last resort would be to involve IT and get them to run www.revouninstaller.com (it's free) and uninstall both versions. Then, at first,install just RH7. If it works, then uninstall 7 and then install both.
Before you do that though, what are you trying to open and how. Are you trying to open a RH7 project with RH X5?
If you are trying to open a RH7 project with RH7, are you opening the application and then browsing to the project? Does the project appear on the Start Page of RH, if it does, then trying clicking the link there instead.
I have tried to open a RH7 project by:
No, the project does not appear on the Start Page of RH.
Thanks again for all of your suggestions!
I asked about the start page as I came across an old note where someone had a similar problem after upgrading from X5 and that fixed it for them. However, if the link is not there, that kills that theory.
I've suggested pretty much everything I can think of. My money would be on RevoUninstaller.
Downloaded Revo Uninsaller and uninstalled RH X5 and 7. Unfortunately, still unable to open xpj files. Really stuck now!
What level of uninstall did you use?
Did you just reinstall RH7 as suggested?
Also are you 100% sure you have admin rights when installing?
i used Advanced level of uninstall and yes, I reinstaalled RH7 as suggested. My IT guy gave me a new rebuilt computer and I am able to open xpj files on it so although we did not find out what was causing the problem, I am able to update the necessary files. Thanks again for all of your help!
Step 2. Open a window on the top floor of your building, make sure there is no one below, ...
