Hello there,
I am using RH 7.03, generating WebHelp
I am creating branded Help and would like to customize the name that displays on the browser tab. It is set via the Project Title property in Project Settings. Can this be changed dynamically via an ssl?
Many thanks.
Pat
Hi Pat.
Have you checked the "Window Caption" setting in the properties of the window you are using?
Read the RoboColum(n) for a tips, tricks and musings on the Technical Communication Suite products.
Hi Pat
To expound on what Colum offered, that setting will only have any effect under one of a couple of conditions.
Aside from either of those conditions, the Window you were pointed to will be simply ignored.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
You have stated what controls that text so I am not sure what you are asking.
If you want different text for the two layouts, you have to change to title or cheat. Open the start page of the output in a text editor and change the title there.
My webhelp output is generated using the command-line compiler; it makes no sense to change the name of the project to control this setting, and the setting is not accessible through the .ssl, which is a pity. Our solution will be to do some post-processing duirng our build process on the output .html file in order to display our branded product name in the brower Tab.
Hi there
If you feel there should be more control over this aspect of building help, please submit a Wish Form to ask for it to be considered.
Cheers... Rick
