I have recently upgraded to CP4. I have added audio to slides, which I can hear OK when I review the slide (F3), but when I run the project - there is no audio.
Must be a simple setting somewhere, but I cannt find anything to help..
Noel
England
If i get you correctly, once you insert audio inside Captivate, you are able to play it using F3. But it does not play when you preview / publish and run your movie.
- Can you double click on the slide carrying audio and go to audio tab
- Check if you can play the audio file in this dialog.
Can you also tell us your system configuration?
Mukul
Thanks for fast reply.
Correct - I can hear audio OK when I preview using F3 option, but not then
I preview "full slide".
I can hear the audio when I run it in the "audio tab".
System details as below
Noel Griffiths, Bhm MV-TI
Corporate Customer Solutions, eLearning
Tel: +44 (0) 121 352 2540 (Direct)
Mob: +44 (0) 7785 388 336
@: noel.griffiths@kuehne-nagel.com
KNet: http://knet.int.kn/bu/cs/sales_support_training/
Spark ID: noel.griffiths
“If you don't know where you are going, any road will get you there.”
THE GLOBAL LOGISTICS NETWORK - 54,000 STRATEGICALLY LOCATED SPECIALISTS -
850 LOCATIONS - 100 COUNTRIES
forums@adobe.com
22/10/2009 07:43 To
cc
Please respond to
clearspace-153621 Subject
3438-119379-2-233 Cannt hear audio in
1458@mail.forums. playback - CP4
adobe.com
and run your movie.
The problem has fixed itself! I re-booted the PC and now all is OK.
Thanks for your prompt reply and offer of help.
forums@adobe.com
22/10/2009 07:43 To
cc
Please respond to
adobe.com
and run your movie.
