Hi
I'm using Adobe Captivate 3
I have created a menu builder that links to other sections (Captivate projects). I have set the properties for the links in the menu builder so they are self contained i.e. the Save file with projects is ticked and the reference is relative (no path) showing in the Link box. Files showing as htm files not swf. All the projects linked have a skin. When running the executable file it gives error message with only letter F on it. I can't think of any thing else to do, obviously it seems that the menu is not finding the linked files. Can any one think why or suggest a possible solution please.
Ana
Hi Ana
Indeed the all too generic "F" message is indicating that your MenuBuilder (MB) exe file cannot find the file it is linking to.
This makes me wonder if you are under the impression that all you need to ship is the final MB result. If that's what you believe, you are mistaken. You need to ship the .EXE MB created as well as the file(s) you are linking to and hoping to open with what MB created. Just make sure all files are in the same folder and you should be good to go.
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Hi Rick
Thanks for your answer. Yes I was under the impression that I only need the MB exe file. Now my question is do I need to ship the swf, htm, and the skin swf file for all links?
Cheers
Ana
Hi again Rick
Following from my today's earlier e-mail. I've copied all the files but still given me the same error message. I'm trying to run the MB exe from a web page, so I can send the URL to users. Which means that it's maybe creating a temp files so it can't locate the links. Any ideas please.
Atika
Hi there
I see multiple issues with that. First off, you really don't want to run a .EXE from a web page. There is simply no way to seamlessly do it. The user will forever be prompted with what to do with the file. Run it? Save it to the hard drive? I'd use MB to create flash based output to pop up on the web if that's what you are doing.
But assuming you wish to continue that way, you might try creating your links in MB so they point to valid URLs instead of simple pathing.
For example, link to http://www.SomeSite.com/SomeFolder/SomeProject.HTM and not simply SomeProject.HTM
And yes, all the files need to be present. Skin.SWF, standard.js, etc.
Cheers... Rick
Hi Rick
Thanks for getting back to me quickly. I have thought of linking to the URLs but have not tried it yet. As for the fist suggestion which seems better, I don't know how to create flash based output, could this be done using Captivate? Or different software?
Hi again
Umm, it's an option when you export your MenuBuilder?
Cheers... Rick
Thanks Rick it works now.
Cheers
Ana
