X5 has to be installed and run with the same logon and with
admin rights attached, both installation and use.
You will not be able to activate it though as that server had
to be pulled for security reasons. You will need to contact
Customer Support for a replacement that does not need activation.
However, that should not stop you using X5 for a limited
period of time, unless it has been on that PC before.
