Since the last update of my Reader (last version is 9.1.3), I can't display pdf form in the workspace. I got a blank page.
Is anybody have the same problem?
Total Likes
I have the same problem too, I reported to the Help Desk and they said that common problem for version 9.1.3. While waiting to get it fixed, I have asked them to roll back to earlier version 9.1.2 and it works fine. If you got it fixed, please post here to share your tip. Thanks. Han
open your acrobat or any pdf file on hard drive
go to edit->preferences
in the side bar click internet and make sure all the check boxes ( display pdf in browser is enabled) are checked.
try if it works
Total Likes
I checked and all checkboxes are checked.
We tried to update the reader to 9.2 version and the problem is still here.
Total Likes
Have you found a solution to this yet? I am seeing it with version 9.3.
John
Total Likes
- Go to the registry HKEY_CLASSES_ROOT > Software > Adobe >Acrobat> delete any older version that is older than the one you just updated to make sure it contains only the current one you have for both Acrobat Reader and/or Pro version since it did not removed when you uninstall or update.
- Also go the installed directory where you installed the Acrobat and delete any folder that contains older version, same here with the registry, it did not remove when you uninstall/update acrobat reader or pro.
The above steps also solve the problem of can not open pdf file within Internet Explorer or browser as well.
Han
Total Likes
I found two hit/miss workaround solutions.
#1: When you get the blank white screen, simply hit the 'ALT' key. Most of the time that seems to force the pdf to render to the screen.
#2: Change the Internet Options to DESELECT 'Allow fast web view' and 'Allow speculate download..." That worked on a couple of my machines.
But I still have not found a silver bullet answer.
Total Likes
Likes
Likes
