Hi
I have urgent requirement where i need to prepopulate the list values in drop down list in the xdp.Here I am able to do prepopulate the value for Text
Box by assigning some value to the particular value in the sub process like location/@Title [Location] and "hsjkghsfkgh" [Expresion]. But i am failing in prepopulating the data for drop down list specially dont know how to specify the List values [Collection] in the expression.
I created a varaible of type list and sub type string and when i have expresion like "APPP" [only one value] , the data is prepopulating in the pdf.
Please help me out how we will specify list in the expresion ?.
Praveen
Total Likes
You need to populate a hidden field (just like you do with Title) with the values for your drop down. Something like a comma delimited list. Then on your xdp, look at the value of the hidden field and create a script that will parse the string and add the elements to the drop down.
Jasmin
Total Likes
Hi Jasmin,
Thanks for your reply.
FYI : I had not used any hidden value to prepopulate the data into TextField. ]
I am using setValue user activity to assign the value into the xfa form.
SetValue activity allows you specify value for particular field in the xfa form(Location).
Here my configuration :
Location : /process_data/xmlPrepareData/xdp/datasets/data/form1/TextField1 ( TextField1 is the name of the TextField in the pdf).
Expression : mmmmm
The above settings are working prettt much.
But I would like to prepopulate the data for drop-down list.
I created the sample pdf with drop-down list and am trying to prepopulate but I am getting first value of the list into the drop-down list.
Location : /process_data/xmlPrepareData/xdp/datasets/data/form1/DropDownList1
Expresion : /process_data/sampleOutput (Created sampleOutput variable as list(sub type -string).
Adding values as
Please let me know how can i write my list values in the expresion.
Praveen.
Total Likes
You cannot set the list value of a drop down using xPath.
What I'm suggesting is to set the value of a text field, just like you're doing. The value of that text field would contain a comma delimited list of the drop down values.
Then, whithin the form (OnFormReady or somehting), run a script that would read the value of that text field and parse the comma delimited string and populate the drop down value.
Jasmin
Total Likes
All the script is there ready for use as part of a custom object called 'Process Fields'.
Set the value of AWS_CHOICE on initialise to a comma delimited string and the drop-down AWS_ACTION will populate the elements.
In the sample attached you will see all the parts of the Process Fields object. You can delete what is not needed. I have set this.rawValue of AWS_CHOICE to "1,2,3,4,5" on initialise.
Total Likes
Sorry it did not upload the file for me but I think my reply is clear enough. If it is not then I'll happily explain more
Total Likes
