I use a web service (use to be CFTTP and was working fine thanks to Ian Skinner) for a VIN decoder (Vehicle Identification Number) they charge per request and i can get all the car options in 3 language, they provided me with the CFM file i need to do the request and i got that part to work fine. but i need to save the XML result so i can have all the options on our server and not having to request it everytime we need to see it.
So this is the CFM that gets the vin from the web service. I need to know if it is possible to get the XML out of there and save it to a file.
<cffunction name="isNull" returntype="string" output="false">
<cfargument name="test" type="variableName" required="Yes">
<cfif isDefined(test)>
<cfreturn Evaluate(test)>
<cfelse>
<cfreturn "">
</cfif>
</cffunction>
<cfscript>
webService = createObject("webservice", "MY_VIN_WS");
countryCode = "US";
languageCode = "en";
if( IsDefined("url.countryCode") ){
countryCode = url.countryCode;
} else {
countryCode = "US";
if( IsDefined("url.languageCode") ){
languageCode = url.languageCode;
} else {
if( languageCode EQ "es" AND countryCode EQ "CA" ){
if( languageCode EQ "fr" AND countryCode EQ "US" ){
accountInfo = StructNew();
accountInfo.accountNumber = "MY_ACCOUNTx";
accountInfo.accountSecret = "MY_PASSWORD";
accountInfo.locale = StructNew();
accountInfo.locale.language = languageCode;
accountInfo.locale.country = countryCode;
version = "";
dataVersionsRequest = StructNew();
dataVersionsRequest.accountInfo = accountInfo;
dataVersions = webService.getDataVersions(dataVersionsRequest);
for (i = 1; i LTE ArrayLen(dataVersions); i=i+1) {
if (dataVersions.country EQ "US"){
version = dataVersions.country & " " & dataVersions.build & " (" & DateFormat(dataVersions.date) & " " & TimeFormat(dataVersions.date) & ")";
</cfscript>
<cfif IsDefined("url.vin")>
<cfscript>
returnParameters = StructNew();
returnParameters.useSafeStandards = IsDefined("url.useSafeStandards");
returnParameters.excludeFleetOnlyStyles = IsDefined("url.excludeFleetOnlyStyles");
returnParameters.includeAvailableEquipment = IsDefined("url.includeAvailableEquipment");
returnParameters.includeExtendedDescriptions = IsDefined("url.includeExtendedDescriptions");
returnParameters.includeExtendedTechnicalSpecifications = IsDefined("url.includeExtendedTechnicalSpecifications");
returnParameters.includeRegionSpecificStyles = IsDefined("url.includeRegionSpecificStyles");
returnParameters.includeConsumerInformation = IsDefined("url.includeConsumerInformation");
returnParameters.enableEnrichedVehicleEquipment = false;
vinRequest = StructNew();
vinRequest.accountInfo = accountInfo;
vinRequest.vin = url.vin;
vinRequest.manufacturerModelCode = url.manufacturerModelCode;
vinRequest.trimName = url.trimName;
vinRequest.wheelBase = val("url.wheelBase");
vinRequest.manufacturerOptionCodes = ListToArray(url.manufacturerOptionCodes, ",");
vinRequest.equipmentDescriptions = ListToArray(url.equipmentDescriptions, ",");
vinRequest.secondaryEquipmentDescriptions = ListToArray(url.secondaryEquipmentDescriptions, ",");
vinRequest.exteriorColorName = url.exteriorColorName;
vinRequest.returnParameters = returnParameters;
vehicleInfo = webService.getVehicleInformationFromVin(vinRequest);
showInstallCause = IsDefined("url.includeCauseChain");
</cfscript>
</cfif>
I also attach the entire file if you need to see it
Help would be greatly appreciated
There may not be an XML for you to save. That would depend on what features the builders of the web service have provided in their API. If there is a function in the web service that returns the data in an XML format then that is what you would use, if this does not exist you will have to do it manually.
If XML is the goal and a function does not exist to get it, you would just create your own XML format, calling the various functions on the web service API to get the desired data for each node of your XML document.
If just persisting the object is the goal, you may want to look at the <cfwddx....> tag and|or serialization of the obect you received from the web service.
Is there a way i can save the result in an HTML file then ?
Like Ian said, it depends on what they give you. Either look through the web service provider docs or do a cfdump of the webservice object. Look for any methods that may return the XML or HTML. If you find that, then saving that file is trivial because that data will be in the variable.
To expand on the previous answer a little.
You can only consume what the web service gives you. If they provide some method that allows you to get all the data in one bite then it is quite easy to save that data in any number of formats with ColdFusion.
If the web service does not give you a one method for it all choice then there is nothing you can do to change that. You will have to use the methods they do provide you to pull the data out piece by piece and build it all together into a format of your choice. Once you have built something, it is the same trival process to save this with ColdFusion as it would be in the first option above.
How would i do a dump of that service ? If i can do that it would be a lot easier but i cant figure out how.
I manage to get it in HTML format and save it there must be a way to get it in XML
Just dump the variabel you stored the webservice call in.
<cfset myWebServiceVar = createObject ("webservice","url.to.webservice.wsdl")>
OR
<cfinvoke webservice="url.to.websservice.wsdl" retrunVariable="myWebServiceVar"...>
<cfdump var="#myWebServiceVar#>
P.S.
NOTE: This will dump the highest level methods of the webservice. Often, with complex webservices, you will have to drill down from these top level functions to find other available functions.
I.E.
<cfdump var="#myWebServiceVar.methodOne()#>
OR
<cfdump var="#myWebServiceVar.methodTwo(someKeys).subMethodThree()#>
Ok using the DUMP i manage to get this :
<cfset WS_var = createObject ("webservice","mywebservicename")>
<cfoutput><cfdump var="#WS_var#"></cfoutput>
Now i'm trying to use CFinvoke to pass the username nad password and a vin number to get an actuel XML from a decoded VIN then saving it has an XML file on my server but i cant get it to work can you please check my code out. And also would that work ?
<cfinvoke method="getVehicleInformationFromVIN" webservice="aa_chrome" retrunVariable="WS_vartest">
<cfinvokeargument name="USERNAME_PROPERTY" value="myuser"/>
<cfinvokeargument name="PASSWORD_PROPERTY" value="mypass"/>
<cfinvokeargument name="VIN" value="an actual vin"/>
</cfinvoke>
<cfset XMLText=ToString(WS_vartest)>
<cffile action="write" file="C:\mypath\mytest2.xml" output="#XMLText#">
Thank you very much for the help so far.
What do you mean by "can't get it to work"? What's happening instead of it working?
Adam
This may or may not solve the problem, but you should get it out of the way: returnVariable instead of retrunVariable.
This is what is happening
<cfinvoke method="getVehicleInformationFromVIN" webservice="ws_name" returnVariable="WS_vartest">
<cfinvokeargument name="language" value="en"/>
<cfinvokeargument name="country" value="CA"/>
<cfinvokeargument name="VIN" value="1FMFU2058********"/>
</cfinvoke>
Web service operation "getVehicleInformationFromVIN" with parameters {country={CA},VIN={1FMFU20586*****},language={fr}} could not be found. | |
The error occurred in C:\mypath\test_vin.cfm: line 6 | |
4 : <cfinvokeargument name="language" value="en"/> |
what i m doing wrong
Gear_Head,
There is some confusion. In your posts, you've defined the webservice function getVehicleInformationFromVin in 3 different ways, namely
getVehicleInformationFromVin(vinRequest), where vinRequest is a struct
getVehicleInformationFromVIN(USERNAME_PROPERTY, PASSWORD_PROPERTY, VIN)
getVehicleInformationFromVIN(language, country, VIN)
So, which one will it be?
The last 1
This suggests there is no function having the arguments {country,VIN,language} in the web service.
I'm really new to Web Service how do I send the vin number usigng Cfinvoke ?
Three choices
<cfinvoke webservice="#WSVariable#"....>
<cfinvokeArgument name="VIN" value="#vinValue#">
</cfinvoke>
OR
<cfset argumentStruct = structNew()>
<cfset argumentStruct.VIN = vinValue>
<cfinvoke webservice="#WSVariable#" argumentCollection="#argumentStruct#"...>
OR
<cfinvoke webservice="#WSVariable#" VIN="#vinValue#"....>
| h1. Web service operation
{country={CA},VIN={1FMFU20586*****},language=} could not
be found.
That type of error often means CF is unable to match up the values you are passing with one of the webservice methods. Some common causes are when the number (or type) of arguments do not match the method parameters.
For example
A) Passing three (3) strings to a method that only expects two (2) strings
B) Passing three (3) strings to a method that expects two (2) strings and one (1) number
Can you post a snippet of wsdl, specifically the portion that defines getVehicleInformationFromVIN and its parameters?
