As a general rule, it is better to use db functions than cf
functions in situations like this. I don't use mysql myself, so I
don't know if it has a function that returns the current date and
time. But if it does, you should use it.
If not, use the cf createodbcdatetime function, not
dateformat.
cf functions in
Sorry, yes, agreed. If I was setting the CURRENT date, I'd
use a DB
function to do it. If I was setting any other date, I'd use
<cfqueryparam>
to pass it.
In answer to your actual question, and in a summary of the
others, you should have been using CreateODBCDDateTime whether
using Access or SQL or any other database... it looks like before
it was being put into a text field since you had quotes around it.
