1. Re: "Cells too small to split". As per usual.
Peter Truskier Oct 31, 2009 12:12 PM (in response to Jeremy bowmangraphics-DQuh1B)Hi Jeremy,
I've not seen this message, probably because we usually do have explicitly defined tables using the aid namespace.
A wild guess, though, would be that it has something to do with the fact that by default, newly created table cells have a text inset of 4 points. What happens if you create a new cell style with no text insets, and as wide as possible a minimum-maximum row height setting; assign that cell style to the "[Basic]" table style (or whatever other table style you are using)? Does that change the behavior, and if so, is it for the better?
2. Re: "Cells too small to split". As per usual.
Jeremy bowmangraphics-DQuh1B Oct 31, 2009 12:51 PM (in response to Peter Truskier)Hi Peter,
Thanks -- that's a very interesting suggestion that hadn't occurred to me before.
Unfortunately, I've gone through the "turning-the-computer-off-then-on-again" process, so -- for a while -- my importing XML into tables seems to be going well. Alas -- it cannot last. So although I'm not sure when my old friend "Cells too small to split" will turn up again, I know he will and when he does, I'll let you know how your suggestion goes.
Thanks again -- great suggestion!
Jeremy
3. Re: "Cells too small to split". As per usual.
thedesmodus Feb 20, 2012 2:47 AM (in response to Jeremy bowmangraphics-DQuh1B)I have the exact same message here. What in my case the issue seems to be is that I have a linked XML file that I update. This works great until I add a new table to the original XML file. Then my update gives the "Cells too small to split" error, and it will not update.
Creating a new document and importing the XML from scratch does work. For us not the ideal way to work, since I now mannualy have to do a "override styles" on each table again.
I have reset my table-styles to a style with an embedded body-cellstyle with 0 inset. I would have no clue as to how to set a minumum row-height and width in a cell or table style though.
Would be great if anyone has found a solution in the meantime.
