Good evening all,
I have two <cfselect>s in my form, I want to count how many values the user select and save that count to my database. Anyone seen this before? I would like to accomplish this, any help is very welcome.
DJ Khalif
Suppose the fields are called select1 and select2. You could, in the action page, do something like listLen(form.select1)+listLen(form.select2). After all, a multiple selection will produce a comma-delimited list.
Remember the cfselect attribute multiple="yes", which enables a user to select multiple items!
BKBK,
Thanks. I do have another question:
How do I INSERT that list into SQL with same ID number for each item in list that is the same as the ID of the main table?
djkhalif
<cfquery>
insert into yourtable (id, otherfield)
select 1, ''
from some_small_table where 1 = 2
<cfloop list = "#form.something#" index = "something">
union
select distinct #id_variable#, '#something#'
closing tags
Dan,
This is my "INSERT" Code:
<cfquery name="finalInspectionInsert" datasource="#REQUEST.datasource#">
INSERT INTO tbl_FinalInspAttr (DateInsp, INspby, WorkOrder, Total_Insp, Total_Defective, Total_Defects, Notes, Fitem, Model, Battery_Type, Cells, NoPlates)
VALUES('#Trim(FORM.DateInsp)#',
'#Trim(FORM.Inspby)#',
'#Trim(FORM.WorkOrder)#',
'#Trim(FORM.Total_Insp)#',
'#Trim(FORM.Total_Defective)#',
'#Trim(FORM.Total_Defects)#',
'#Trim(FORM.Notes)#',
'#Trim(FORM.Fitem)#',
'#Trim(FORM.Model)#',
'#Trim(FORM.Battery_Type)#',
'#Trim(FORM.Cells)#',
'#Trim(FORM.NoPlates)#')
</cfquery>
<!-- Insert Final Inspection into the Final Defects table -->
<cfquery name="finalDefects" datasource="#REQUEST.datasource#">
INSERT INTO tbl_Final_Defects (ID, Unit, DefectCode)
SELECT ID, '#Trim(FORM.Unit)#', '#Trim(FORM.DefectCode)#'
FROM tbl_FinalInspAttr
WHERE tbl_FinalInspAttr.WorkOrder = '#FORM.WorkOrder#'
<cfloop list = "#FORM.UNIT#" index="j">
UNION
SELECT DISTINCT #UNIT#, '#j#'
FROM tbl_DefectTypes
</cfloop>
</cfquery>
Dan,
This is my Confirmation Page. The use will see this for proceding to action (INSERT) page.
<cfquery name="rsItemLU" datasource="#REQUEST.datasource#">
SELECT i.Item, i.Model, i.Model_Adder, i.Type, i.Plates, i.Cells
FROM tlkp_Item AS i INNER JOIN
tbl_Assembly_Production AS p ON p.Item = i.Item
WHERE (p.WorkOrder = '#FORM.WorkOrder#')
GROUP BY i.Item, i.Model, i.Model_Adder, i.Type, i.Plates, i.Cells
</cfquery>
<cfset list1 = "#FORM.total_defective#">
<cfset list2 = "#FORM.total_defects#">
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="/Templates/atDatTemplate.dwt.cfm" codeOutsideHTMLIsLocked="false" -->
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title><cfoutput>#REQUEST.companyName#</cfoutput></title>
<link rel="shortcut icon" href="/images/favicon.ico">
<link href="/finalCut.css" rel="stylesheet" type="text/css" />
<cfset copyRight = DateFormat(now(), 'yyyy')>
</head>
<body>
<!---<div id="header"></div> --->
<div id="contentContainer"><div id="topNav" style="font-family:'Trebuchet MS'; font-size:11px; padding-left:60px;"><cfinclude template="../includepages/topnavigation.cfm"/> </div>
<div id="centerCol"><!-- InstanceBeginEditable name="editCentCol" -->
<b>Date Inspected:</b><cfoutput>#DateFormat(FORM.DateInsp, 'mm/dd/yyyy')#</cfoutput>
<br />
<b>Work Order:</b><cfoutput>#FORM.WorkOrder#</cfoutput>
<br />
<b>Inspected by:</b><cfoutput>#FORM.inspBy#</cfoutput>
<br />
<cfoutput>#FORM.inspectedByName#</cfoutput>
<br />
<b>Total Inspected:</b><cfoutput>#FORM.Total_Insp#</cfoutput>
<br />
<b>Total Defective:</b><cfoutput>#ListLen(FORM.total_defective)#</cfoutput>
<br />
<b>Total Defects:</b><cfoutput>#ListLen(FORM.total_defects)#</cfoutput>
<br />
<b>Comments / Notes:</b><cfoutput>#FORM.notes#</cfoutput>
<h3 style="font:Trebuchet MS; font-size:12px;">Battery Description</h3>
<cfif isDefined ("form.WorkOrder")>
<p style="font:Trebuchet MS; font-size:11px;">
<cfoutput query="rsItemLU">
<b>Item:</b> #Item#<br />
<b>Model:</b> #Model#<br />
<b>Adder:</b> #Model_Adder#<br />
<b>Type:</b> #Type#<br />
<b>Cells:</b> #Cells#<br />
<b>Plates:</b> #Plates#
</cfoutput></p>
</cfif>
<cfif listlen(list1) gt 0>
<cfloop from="1" to="#listlen(FORM.Total_Defective)#" index="j">
<cfoutput>#listGetAt(FORM.Total_Defective, j,",")# </cfoutput>
</cfloop>
<br />
<cfloop from="1" to="#listlen(FORM.Total_Defects)#" index="k">
<cfoutput>#listGetAt(FORM.Total_Defects, k,",")#</cfoutput>
</cfloop>
</cfif>
<cfform name="inputFinalInspection" action="../ActionPages/finalinspectionaction.cfm">
<cfinput name="Back" type="button" value="Back" onClick="history.go(-1)">
<cfinput name="submitValues" value="Submit" type="submit" />
<cfinput type="hidden" name="DateInsp" value="#DateFormat(FORM.DateInsp, 'mm/dd/yyyy')#">
<cfinput type="hidden" name="InspBy" value="#FORM.inspBy#">
<cfinput type="hidden" name="Total_Insp" value="#FORM.Total_Insp#">
<cfinput type="hidden" name="Total_Defective" value="#ListLen(FORM.total_defective)#">
<cfinput type="hidden" name="Total_Defects" value="#ListLen(FORM.total_defects)#">
<cfinput type="hidden" name="Notes" value="#FORM.notes#">
<cfinput type="hidden" name="FITEM" value="#rsItemLU.Item#">
<cfinput type="hidden" name="Model" value="#rsItemLU.Model#">
<cfinput type="hidden" name="ItemDesc" value="#rsItemLU.Model_Adder#">
<cfinput type="hidden" name="Battery_Type" value="#rsItemLU.Type#">
<cfinput type="hidden" name="Cells" value="#rsITemLU.Cells#">
<cfinput type="hidden" name="NoPlates" value="#rsItemLU.Plates#">
<cfinput type="hidden" name="Unit" value="#listGetAt(FORM.Total_Defective, j, ",")#">
<cfinput type="hidden" name="DefectCode" value="#listGetAt(FORM.Total_Defects, k,",")#">
</cfform>
Are you storing the list FORM.total_defective into a database column? That is usually to be avoided.
