Hi, currently i'm using robohelp html version 8. I have spent quite some time to figure out how to change topic's Icon and show the Print Button in my project. Anyone can help me on this? Btw, i using MX(template) to generate the output with FlashHelp Pro.
Below is the screenshot for clearer clarification:
Thanks.
These are all elements that should be able to be modified inside your Flash skin. Note I am not a Flash expert though so can't advise further.
Read the RoboColum(n) for a tips, tricks and musings on the Technical Communication Suite products.
Follow the RoboColum(n).
But to edit your Flash skin, you need to be a Flash Developer.
The Print button is an option in the wizard but I believe it is not working in RoboHelp 8.
@petergrainge
Is that any other way to change the topic icon or Print button in RoboHelp itself instead of using flash sw?
We would have told you if there was.
Sorry but a downside of FlashHelp is that your customising options are limited.
Follow me @petergrainge
