ROBO 8 HTML has encounter a problem and needs to close
Nov 02, 2009 Nov 02, 2009
I can get ROBO to open, but then almost immediately I get this message.  What do I need to do.  I cannot work on my project until I get it fixed.  Thanks.
716
Community Expert , Nov 02, 2009 Nov 02, 2009
After making a backup, rename the CPD and try again.
Post back with the result please.
@petergrainge
@petergrainge
That worked.  Thanks a lot.  Do I need to change it back to what it was or leave as the changed name?
You will find that RH has created a new CPD with the original name and that is the one it is using now. The one you renamed can now be deleted or you may prefer to put it in a temporary folder until you are entirely sure all is OK.
@petergrainge
Guest
Nov 03, 2009 Nov 03, 2009
Hi Peter,
Your tip helped me to fix the same problem that I faced. But, my TOC is getting lost. What should I do to fix that?
Lata
Create a new TOC selecting the Copy option, then browse to the old TOC that should still be in the project files. Designate that as the default and then delete the other TOC from Project Manager and the old hhc file from the project files using Windows Explorer.
Backup first.
@petergrainge
I think this is a continuing problem from the problem above.  When I opened the project this morning, I am missing several files on the project side, therefore creating a lot of broken links.  They are still in the project when I open it in Windows explorer.  How do I get them back in the project?  I did make a backup yesterday.  Should I change the cpd file name on that one and see if the files show up?  Thanks.
Please see the announcement at http://forums.adobe.com/community/robohelp/robohelp_html
@petergrainge
RoboHelp Documentation
Download Adobe RoboHelp
