I am running a 508 accessibility test on forms created in Adobe. The issue that I am having is that when I verify the tab order, it skips the second or any other check boxes in a check box group. Does anyone know where to set it to recognize all the boxes in a check box group?
Solved! Go to Solution.
Total Likes
I have 9.2
If memory serves me correctly there was a bug oin this area and a later service pack fixed it.
Paul
Total Likes
The group has the tab stop. Once inside the group the arrow keys are used to move inside of the group. You cannot create a tab stop inside of a group.
Paul
Total Likes
Thank you for the quick reply. However that did not correct the issue. When I tried to arrow over to the next answer selection the cursor does not move. Do I need to change a setting in the check box group for this to occur?
Total Likes
Works for me .....here is an example
Paul
Total Likes
It did not work on that test form either. What version of Adobe Professional are you using? I am using 8.1.
Total Likes
I have 9.2
Paul
Total Likes
Paul,
Thank you. You were correct, it was a version issue. When I opened the form in Reader 9 with JAWS 10, I was aable to arrow through all of the check boxes with correct identification of each field. Thanks again for all your help.
Total Likes
