The request failed with HTTP status 401: Non-Autorisé.
Avatar
Level 2
i create a process in workbench
i callit via a soap in my dotnet project with this url :
http://name_serveur: port/soap/services/Name_process?wsdl
when i add this as a web reference it runs ok.
for invoking it i write this :
ProcessService
essaiOutput = new ProcessService();
essaiOutput.invoke(
"c:\\creerPdf", "BonCmdeDynamiq.xdp",out outResult,out generatePDFOutputResultDoc);
but when i execute it on a browser i have an error :
the request failed with http status 401 : non autorisé
is anybody know what is the problem?
Avatar
Level 10
You need to change some setting of your service.
See the attached screenshot shows the step by step tasks to be done in the adminui.
Settings are:
Require Callers to Authenticate = No
Specify Run As = System
This should work.
Nith
Avatar
Level 8
Non-Autorisé. - my French is pretty bad, but doesn't that mean "Not authorized"?
LiveCycle services are secured by default. You can remove the server side security (as Nith suggests) - but you'll need to do that for EVERY service you call and all of the operations that service calls.  Also you administrator may not be happy about disabling security :-)
To call it securly, you'll need to set the username and password using a System.Net.NetworkCredential object in your .Net code.
Avatar
Level 2
thanks a lot
finally i have found that i forget to configure my service so now i don't have this error. But i have an other problem..
in my process workbench,for the operation generatePdfOutput i don't know how to define the variable input data :
if  i set :
- input data= variable string input required and i write in the invoke méthode process.invoke("filename","c:\data.xml",....)
i have the error :  The Long Lived Service EssaiOutput can not be invoked synchronously.
or
-input data =  variable xml with xml schema that i provide, but in this case i don't know how to link with my xml file, i try to put this variable to input and write in my code in my project dotnet
WebReference.XML inXml =
new XML();
inXml.document =
"C:\\creerPdf\\PurchaseOrder.xml"
after that i put inXml in the parameter of my method but it doesn't run i have this error
org.xml.sax.SAXParseException: Content is not allowed in prolog
can you drive me to a better solution??
Avatar
Level 8
If I remember right the XML data parameter isn't looking for the filename of the XML data, but it is the data (in a string) itself. The " Content is not allowed in prolog" message means - "this is not valid XML".  In your .net application, read in the XML into a string variable and then pass that variable to the LiveCycle server (rather than the path to the file)
Avatar
Level 2
ok i change my mind : i set input data as a vriable document
and i do that :
BLOB inData = new BLOB();
String inPutFile = "C:\\creerPdf\\PurchaseOrder.xml";
FileStream fs = new FileStream(inPutFile, FileMode.Open);
int longueur = (int)fs.Length;
Byte[] byteArray = new byte[longueur];
fs.Read(byteArray, 0, longueur);
inData.binaryData = byteArray;
and i put indata in the parameter of my invoke methode
and as usual i have an error again this :
System.InvalidOperationException: Response is not well-formed XML. ---> System.Xml.XmlException: There is an unclosed literal string. Line 3, position 64366.
so i look in my xml file but to my mind there is no error
i join with this message mine xml.file
if somoene could say me what it is wrong it would be wonderfull!!!
thanks
Avatar
Level 8
The LiveCycle log is usually more verbose about the actual error than the SOAP error.  Can you access your LC server and see what that error log is saying?
Avatar
Level 2
thanks hodmi your answer help me very much.
in fact my problem is that i don't configure correctly my operation generatePdfOutput in my process, specially the paramètre.
actually when i call the invoke method render nothing in the output parameter :
generatePDFOutputResultDoc and outResult.
i invoke my process like that :
generatePDFOutputMetaDataDoc =
essaiOutput.invoke(
"c:\\creerPdf", inData, "BonCmdeDynamiq.xdp", out outResult, out generatePDFOutputResultDoc);
with indata, outResult, generatePDFOutputResultDoc as blob
in my process i configure the generatePDFOutput operation like that :
INPUT
          transformationformat : PDF
          Form(variable) : FormName(string, input, required)
          ContentRoot(variable): CheminForm(string, input, required)
PDFOutputOption(LiteralValue)
          General :
                         xci uri : empty
                         character set : empty
                         locale : empty
          Batch :
                         recordName : purchaseOrder
                         recordLevel : -1
                         Generate MultipleStream : true
          Rules :
                         patternMatchSize : 500
          Destination :
                         all is empty in this part.
          MetaData :
                         Metadatafilespec : empty
                         RecordId Xpath : empty
                         GenerateRecordLevelMetaData : false
Render Option(Litteral value) :
          Acrobat & PDFVersion : auto
          TagedPdf : false
          linearized pdf : false
          RenderatClient : auto
          DebugEnabled : false
OutPut:
          PDFOutput(variable) : PdfOut (document, output)
          MetaDataDocument(variable) : metaOutPut (document, output)
          OutPutResult(variable) : outResult (outputResult, output).
1. is anybody has got an idea of what is wrong in my config??
2. what is the parameter which can give me the number of pdf generate?
thanks for your help
