1. Re: Submit completed form as pdf excluding previous pdf pages.
Bill@VT Nov 5, 2009 3:30 AM (in response to DP_MC)Change the submission to be just the data, not the form. Select FDF, XFDF, or XML. For your application, I would use FDF. If this form is for others to e-mail back to you, then be aware that e-mail submission is subject to problems that you can not prevent (all associated with the client machine configuration). Thus submission to a web script is ALWAYS preferred. Also, you may want to save the from as backward compatible to be sure folks with older versions of Acrobat or Reader do not have problems with it. Backward compatibility can be obtained with Document>Reduce File Size or with the PDF Optimizer. If you used some new features, they will be lost (but of course those are the features that would have caused problems).
Once you have the FDF file, you can simply import it into the form (in some cases, just clicking on the FDF will open it in the form if you did not move the form on your system. You can then export the data to other formats (see the manual for more info, or just play around with it).
2. Re: Submit completed form as pdf excluding previous pdf pages.
DP_MC Nov 5, 2009 5:44 AM (in response to Bill@VT)This works happily thank you for the rapid response..
If one wanted the completed form pdf emailed back and I am sure there will be a request for it sometime, would attaching the form to the main pdf (or brochure pdf if you like) be the only route to go? Some clients have small mailouts and do not have Acrobat Pro.
