1. Re: missing fonts Photoshop CS3 in Win 7
John Joslin Nov 4, 2009 11:02 PM (in response to IsleofGough)How did you install the fonts?
2. Re: missing fonts Photoshop CS3 in Win 7
Mylenium Nov 5, 2009 12:21 AM (in response to IsleofGough)What PostScript fonts are they exactly? If they are printer fonts, they may be flagged specifically so they can't be used in some products. That is, they may only allow to use their cached bitmap version for typing, but not generate vector contours for editing. That aside, have you tried to flush your AdobeFnt.lst files and your system font cache (C:\Windows\System32\FntCache.dat)? thast is usualyl a good place to start.
Mylenium
3. Re: missing fonts Photoshop CS3 in Win 7
IsleofGough Nov 5, 2009 7:04 AM (in response to Mylenium)Deleting the font cache files did not help, nor did copy the postscript files to Adobe's common font folder or to Photoshop's font folder. The particular font I wanted to install was Teff's trinite font, but I discovered this is a problem with any postscript files from any company (Tiro Typeworks, Monotype, etc.). I haven't seen this described with Win 7, but searching for a solution, I found that this seems to be an issue with Windows 64 bit systems (XP and Vista) and PS fonts and CS3 products. The only solutions I've found were to use otf fonts (not possible with trinite) or upgrade to CS4 (not something I plan to do, as it is too buggy in Premier, Encore, etc. and I will wait for CS5). Thanks.
The installation was directly through Win 7 "install font" option. As mentioned, these fonts work fine with Framemaker and MS Office 2007 products.
4. Re: missing fonts Photoshop CS3 in Win 7
John Joslin Nov 5, 2009 7:07 AM (in response to IsleofGough)Interesting. Maybe it's because PS fonts are on the way out.
