11 Replies Latest reply: Nov 8, 2009 11:06 AM by Stuart Haiz RSS
    Help with css float
    Stuart Haiz Community Member
      I have a layout that I need help with please. The bright green panel is going to have a Flash file inserted but I need it to sit inside the detailsWrapper div, which needs to stretch to allow this to happen. The content is being generated through php modules and the details will vary in length, so I'm having difficulty styling this. I'm sure it's something obvious but I need help please!
      Here's the link: http://www.designermagic.co.uk/hobarts/reapitDetails.php?clearcache=true&pagevars=1-bedroo m-property-for-sale-in-London-N22-hobrps-ALE090002
        • 1. Re: Help with css float
          E. Michael Brandt Community Member
          Try adding this css to your style sheet:
          div#detailsWrapper [
               overflow:hidden;
          if that does not work well, you can try overflow:scroll
          OR alternatively you may be able to do this:
               float:left;
          For other options see this:
          http://tjkdesign.com/articles/clearing-floats_and_block-formatting_context.asp
          E. Michael Brandt
          www.divahtml.com
          www.divahtml.com/products/scripts_dreamweaver_extensions.php
          Standards-compliant scripts and Dreamweaver Extensions
          www.valleywebdesigns.com/vwd_Vdw.asp
          JustSo PictureWindow
          JustSo PhotoAlbum, et alia
          • 2. Re: Help with css float
            Thanks Michael
            Unfortunately, no luck! I'll have alook through the link and see if I can find anything there.
            • 3. Re: Help with css float
              Nancy O. CommunityMVP
              Your CSS code could use some tidying up. It's kind of a mess.  See details below.
              http://jigsaw.w3.org/css-validator/validator?profile=css21&warning=0&uri=http%3A%2F%2Fwww. designermagic.co.uk%2Fhobarts%2FreapitDetails.php%3Fclearcache%3Dtrue%26pagevars%3D1-bedro om-property-for-sale-in-London-N22-hobrps-ALE090002
              These statements are redundant.
              html, body, div, span, applet, object, iframe, h1, h2, h3, h4, h5, h6, {
                  margin: 0;
                  padding: 0;
                  border: 0;
                  outline: 0;
                  font-size: 100%;
              margin: 0;
              padding: 0;
              body {
                  margin-left: 0px;
                  margin-top: 0px;
                  margin-right: 0px;
                  margin-bottom: 0px;
              Try changing the above code to just this.  * = the universal selector.
              margin: 0;
              padding: 0;
              border: 0;
              font-size: 100%;
              outline-style:none; /**outline is not on by default so unsure why you need this**/
              More on CSS Shorthand
              http://www.dustindiaz.com/css-shorthand/
              And you have HTML code errors but the symbols in your document are blocking the validator from giving results.
              http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fwww.designermagic.co.uk%2Fhobarts %2FreapitDetails.php%3Fclearcache%3Dtrue%26pagevars%3D1-bedroom-property-for-sale-in-Londo n-N22-hobrps-ALE090002
              After you fix the code errors, post back with a URL to the new page.
              Nancy O.
              Alt-Web Design & Publishing
              Web | Graphics | Print | Media  Specialists
              www.alt-web.com/
              www.twitter.com/altweb
              www.alt-web.blogspot.com
              • 4. Re: Help with css float
                Hi Nancy
                Thanks for the advice and the helpful links. I have amended the css but can't do anything about the erroneous characters. They are due to data that a client has input and he's out of the office today!
                The link is the same as above - I don't know if you will be able to get anywhere before those charcters are taken out but would appreciate some pointers.
                Below is the area of code in my page that I'm trying to style:
                <div class="detailsWrapper">
                <?php
                $module_obj = new RPW_property_details_obj();
                $module_obj->set_parameter("itemOrder", "price,title,images,buttons,contacts,reference,furnish,availability,brief description,accommodation summary,room by room,location,extras,caveat");
                $module_obj->set_parameter("imageSetWidth","700");
                $module_obj->set_parameter("showFullDetails", 1);
                $module_obj->set_parameter("showRoomDesc", 1);
                $module_obj->set_parameter("roomDescShowName", 1);
                $module_obj->set_parameter("roomDescShowSize", 1);
                $module_obj->set_parameter("roomDescShowDesc", 1);
                $module_obj->set_parameter("units","m");
                $module_obj->set_parameter("showBothUnits", 1);
                $module_obj->set_parameter("mainImageWidth","440");
                $module_obj->set_parameter("mainImageHeight","320");
                $module_obj->set_parameter("imageSetType","lightbox");
                $module_obj->set_parameter("useLightboxOnClick", 0);
                $module_obj->set_parameter("pdfButtonText", "PDF Details");
                $module_obj->set_parameter("mapButtonText", "Location");
                $module_obj->set_parameter("hipButtonText", "HIP");
                $module_obj->set_parameter("emailButtonText", "Email Us");
                $module_obj->set_parameter("showOfficeName", 1);
                $module_obj->set_parameter("showTenure",1);
                $module_obj->write_html();
                <p class="detailsCalc"><br /></p>
                </div>
                Thanks - I hope you can make something of this! BTW - I'm in the UK hence the delays in my replies.
                • 6. Re: Help with css float
                  Your'e gonna kick yourself.  detailsCalc has position:absolute, complete with top/right coordinates, which takes it out of page flow.  Gotta remove that:
                  .detailsCalc {
                  background-color:#00FF00;
                  height:550px;
                  position:absolute;
                  right:10px;
                  top:560px;
                  width:350px;
                  E. Michael Brandt
                  www.divahtml.com
                  • 7. Re: Help with css float
                    Thank you Michael
                    That has helped me to get closer to what I want. I have taken off the position attributes. That didn't work on it's own, it just moved the <p> outside of the detailsWrapper div. I also had to move the html to get the detailsCalc inside the wrapper, (new code below.) I also added a float: right; and tried clearing but that didn't get it where I want either. The problem seems to be that I need to be able to somehow insert my code into the generated content. I have tried using <<<HEREDOC without success. Also attached is an image of where I would like it to be, with the text wrapping to the left of it.
                    Is this something that can be done at design-level?
                    My current code:
                                </p>
                                <?php
                              </div>
                    • 8. Re: Help with css float
                      I've been looking at this for some time now, and cannot see a way clear.
                      The only solution I can see is a messy one, involving re-writing the html client-side using DOM scripting.  It would not fail gracefully though, so would not really consider it.  That said,m I am not really able to map in my mind the relationship of the php code you sent and the page, so if you can see some way to move the green box code into the div <div class="contacts" which unfortuantely has no id, then you might be able to get this to work out.
                      Someone far more clever than I might be able to do this within the constraints imposed upon you by virtue of your not being able to control all the html yourself, so I will sit on the sidelines now and watch who else might pop into the thread.  Sorry I could not help more.
                      E. Michael Brandt
                      www.divahtml.com
                      • 9. Re: Help with css float
                        Michael
                        Thank you ever so much for giving your time to try to help me solve this.
                        Using Firebug, I too came to the same conclusion that I need to get into the contacts div to make this work. Unfortunately, it is part of the generated data and as you say, has no id.
                        I think this might well be a case of trying to do something that is just not possible, unless I can persuade the Property portal to amend the underlying code. That is going to be my only real option unless the client can accept that what they want can't happen!
                        Many thanks.
                        BTW - I use divaFAQ on a few sites and it is always popular with my clients. Thanks too for that.
                        • 10. Re: Help with css float
                          Yeah i do think so.
                          I use divaFAQ
                          Glad you are finding it useful.
                          At this point, since it does seem like this has hit a wall, it might be good to mark this thread as Answered so the folks who help will not have to keep clicking on it.  Thanks!
                          E. Michael Brandt
                          www.divahtml.com
                          • 11. Re: Help with css float
                            Answered! Thanks Michael.
