Peter,
We too deploy on Docent 6.5 and have had no issues with
Presenter content....with ONE notable exception however:
hidden slides. If your content contains any hidden slides at
all, the "Report Slide View" function will throw an incomplete
every single time, regardless of where or when you exit your
course. Don't know if that's an issue for you, or as to whether you
actually have hidden slides or not, but it's worth mentioning
nonetheless.
That said, have you tried running your courses through an ADL
test suite? I ask because I can provide a sample pdf document that
tracks progression, slide by slide, of Presenter content. Much like
us85 has already mentioned, running an ADL test can provide a
simple measure of "conformity", as it does track completion, SCORM
packaging and session variables. Furthermore, in most cases, you
can also track all the cmi.core.session information to determine
validity.
In my mind, having done this numerous times against various
platforms (Docent, Lectora, GeoLearing, PeopleSoft), running the
ADL tests can at least prove SCORM compliance. In addition to
us85's comment, the test suite (version 1.2.6) will throw an
LMSSetValue() as "finished successfully"
Rob
