I am working with RH8 html and am having an issue with the command line build. I could not find anything pertinent from previous posts.
I have a project (640 topics) that is incorporated into a "master project" comprised of 3 merged projects. When I run my batch (.bat) file, the third project (mentioned above) only generates 103 of the 640 topics. The additional 2 projects also encounter a similar problem. This causes my master project to be missing images (and quite possibly topic information, though I have not yet found an instance). There are no error readings.
I place all of my images in a separate folder located in same directory as the .xpj file (e.g. MyProject/Images).
When I generate each project manually in RH, everything works. This leads me to believe that there is a flaw in my .bat file. Perhaps I am not accounting for merged projects correctly?
The .bat file is below (note that %~1 is an arguement representing a directory name):
echo ****Building Tyco Online Help (General Build)****
echo **Clearing File System**
cd %~1\Master Help\!SSL! <--Location of Master Project Single Source Layout
rmdir /Q /S WebHelp
cd C:\Program Files\Adobe\Adobe Robohelp 8\RoboHTML
echo **Compiling IM Help**
rhcl "%~1\IM Help\IM Help.xpj" <--Subproject 1
echo **Compiling TEMS-NMS Help**
rhcl "%~1\TEMS-NMS Help\TEMS-NMS.xpj" <--Subproject 2
echo **Compiling TEMS Help**
rhcl "%~1\TEMS Help\TEMS EUD.xpj" <--Subproject 3
echo **Compiling Master Help**
rhcl "%~1\Master Help\Master Help.xpj"
echo **Copying WebHelp Folder to Desktop**
cd c:\Documents and Settings\nms4400\Desktop
rmdir /Q /S "General WebHelp"
xcopy /S /E /I /Y "%~1\Master Help\!SSL!\WebHelp" "General WebHelp"
Thanks.
Have you resolved this issue with the incomplete build at the command line?
I am generating a single project but am now having this issue, since I added the 8.0.1.204 patch. The project which previously would not be compiled to the specified outout directory, is now created in the location specified by -o, but only 23 out of 442 topics are processed.
